Ana içeriğe geç
Repair and support for the 2015 version of the Google-produced laptop line, the Chromebook Pixel. This newer version improves the processing power, battery life and add new features to the 2013 model.
14 Soru Tümünü görüntüle
Is there any place to buy a replacement battery?
The battery on my pixel 2 has started to become a concern after draining a few times. I've been checking for battery replacements every couple months, but no where on the internet does it seem anyone is selling this, or even looking to buy a replacement battery. I might as well be the first person to ask.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
https://www.ebay.com/itm/NEW-Li-ion-Genu...
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Dude you saved me!
tarafından
This worked perfectly for one of the Chromebook Pixels I was working on.
tarafından
Yorum Ekle
@albertemc2 there are no official replacement parts available for any Pixel. Looks like the battery is a Toshiba model. There is a company that is already shrouded in mystery, black helicopters and even more secretive than Apple. So it will be up to you to try and find one based on the actual battery. The Toshiba battery model is PA5280U-1BRS
Of course you can try places like this to see if they can match it.
Puan 0
Yorum Ekle
Sears has this model posted. seems pretty spendy to me, if i were you I would look around a little more to see if i could find one cheaper, this one seems to be a little over 50.00 YIKES! there might be a way to rebuild your old battery.
http://www.sears.com/es/us/toshiba-pa520...
Puan 0
Yorum Ekle
If you open the Crosh shell (Ctrl+Alt+T) I believe there is a command to test the battery's ability to hold a charge if you run `help_advanced` and look through the commands there.
Also keep in mind the screen brightness and the number of open tabs and the number of extensions you have running in the background can greatly affect your battery life.
I would run the above test once as your user, and then power off the Chromebook complete and boot fresh and rather than logging in again choose the "Guest" session, then use the same command you used in the Crosh shell and see whether the discharge rate is different.
You should also try running as Guest for a day or two and see if there is a large difference in battery life if you aren't logged in as your user with all your extensions/tabs/etc.
Let us know what the results are and we can give you more advice based on that information.
Puan 0
Yorum Ekle
Yanıtını ekle
Albert Einstein sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 1,774
