How to repair damaged power port
How to repair or replace battery charging port
Bu iyi bir soru mu?
Bu iyi bir soru mu?
from your question there is no way for me to tell exactly what the power port you need repaired is on.
if it's a phone, a calculator, or? and what model. there are a lot of things with power ports, some are much easier to fix than others. Most likely though, it's best to remove the old one after buying a new one and then installing the new one. I know that sounds impossible with some Items but you have to remember, it was installed once and so you know it can be installed again, It's just a matter of getting it done.
Bu yanıt yardımcı oldu mu?
ZTE N817 will not charge. It is not the cord. I used to be able to giggle cord and get it charging..cellphone
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 193
