Ana içeriğe geç
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Prohibition Sign on Start Up
iMac won't start up and it shows the "Prohibition Sign" on start up. I went into recovery mode and to disk utility and it doesn't show my fusion drive and it shows no information what so ever. Can anyone help me?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You won't see the Fusion Drive under Disk First Aid, You'll see the discreet drives (HDD & SSD) that combined make up the Fusion Drive set. If you can't mount the drives then you have a deeper problem!
At this point you'll need to use the command line interface of Core Storage following this guide: Fixing a Mac Fusion Drive that Disk Utility can’t erase
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Sounds like your fusion drive has failed.
Try to get ahold of another mac and make a bootable thumb drive for any OS X installer. See if your iMac will boot from this thumb drive. This would verify if your disk has failed or not.
Puan 0
Yorum Ekle
Yanıtını ekle
Name sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 283
