Ana içeriğe geç
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
61 Soru Tümünü görüntüle
Do I need a Windows 10 PC or will the Xbox customize the controller?
I want to customize my controller and I was wondering if a windows pc is required to customize the controller.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The Xbox will allow you to customize your controller’s paddles (along with other buttons). What you will need to do is download the Xbox Accessories App. You can download the app on your Xbox by navigating to the 'Apps' tab on the Xbox dashboard. Then, in the ‘Search all apps’ bar, type in Xbox Accessories. The screen should display the Xbox Accessories App under ‘TOOLS’ which you can then click on and install. Once it’s downloaded, make sure to pin it so it will appear on your homepage. Finally, navigate back to the dashboard’s homepage and it should appear as one of your apps. As an alternative, you can use a PC to customize the paddles by downloading the Xbox Accessories App onto your computer; however, it requires that your operating system is Windows 10.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Sukhdeep Singh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 515
