Ana içeriğe geç
Lenovo IdeaPad, Yoga Series. Released October 2013, 13.3 inch screen, 8 GB RAM, 2 GHz CPU, 512 GB SSD.
15 Soru Tümünü görüntüle
has my moltherboard failed?
When I turn on the computer, the keyboard starts blinking about every 2 or 3 seconds. The screen never lights up. I can turn it off by holding on/off button for 15 or so seconds. But every time I turn it on same thing happens.
Bu iyi bir soru mu?
Puan 2
5 Yorum
Hi @tyng98 ,
Can you hear the fan running?
If so, try connecting an external monitor to the HDMI port to see if there is any display present at all after you turn on the laptop and hopefully Windows has loaded.
If there is a display on the external monitor, try holding a torch at an angle close to the IdeaPad's LCDscreen to check if you can detect an image there.
tarafından
Mine does the same thing and you can't hear the fan spin up when you try to turn it on. It doesn't even post, can't even get to the bios.
tarafından
Hi Lachlan Weibe,
Are there any indications evident when you connect and switch on the charger and then if there are does anything happen when you try to turn the IdeaPad on?
tarafından
I took mine to a local repair shop and their diagnosis was that the memory was bad. Since its soldered to the motherboard, I would need a replacement board to potentially fix it.
The parts and labor was more than the laptop is worth but I'm thinking about buying the motherboard and trying my hand at replacing it.
Amazon has them for about $300.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have had this same model come into my shop with this same issue. I replaced the BIOS chip. No change. I was able to get it to boot for a second by removing the CMOS battery but It blue screened almost immediately. These boards are terrible.
So in short, Yes your motherboard has failed.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I have come to the same conclusion. I found that a motherboard costs about $300. I tried to contact Lenovo, but their customer service would not talk to me once they learned it was out of warranty. I finally wrote a letter to their US office asking them to stand behind their product. Doubt that I will hear from them again.
tarafından
Although this thread has been dead for a while, maybe it helps someone in the future:
My wife's lenovo yoga 2 pro had the same issue. After some googling it seems that this i a common problem caused by some cold solder joints at the interface of CPU/GPU.
We are absolute electronics novices, but with a cheap hot air solder fan at 320 °C and some no-clean flux around the edges of the CPU/GPU board we were able to resolder everything. The notebook now works fine again. For reference we used these (bad) youtube videos:
https://www.youtube.com/watch?v=JbN84HOh...
(he does not use flux, but we applied the heat gun for the some duration at the same area)
disassembly:
https://www.youtube.com/watch?v=QmkNeipb...
tarafından
Good job. More expert than me, at the hot air solder and no flux.
I need to learn component repair.
tarafından
Yorum Ekle
My wife also has this problem with a Surface Laptop. The only solution that I have come up with is holding the power button until the device powers off (abt. 10 seconds) and then turning it back on.
I'm not certain this is the cause, but my wife hardly ever "shuts down" windows. She just prefers to close the lid, which may cause the computer to do a variety of things. All of those settings are available in the power settings menu under "Change what happens when I close the lid..."
Puan 0
1 Yorum:
This did not fix it. I did hold down the power button for 15 seconds and the computer did turn off. But when I powered on again the same blinking occurred. I did take it to a repair shop and they did say it was the motherboard. Thanks for trying to help.
tarafından
Yorum Ekle
Yanıtını ekle
Aaron Knott sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 66
Her zaman: 12,552
