Truck Wont start, fuel pump shorted
1996 K1500
Found fuel pump shorted, changed full assembly. Wont start, ac wont work, doors unlock electric but wont lock, no bad fuses.
Bu iyi bir soru mu?
1996 K1500
Bu iyi bir soru mu?
Is your new pump kicking on? Did you find out what caused the first pump to short out? If you look down the throttle body while it's cranking, is it spraying fuel?(carb press gas and accl pump should squirt a stream) if the fuel pump is not coming on then check the fuel pump relay underneath the hood on the firewall passenger side when the key is turned on listen for a click.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 205
Battery is fully charged. WAs disconnected for work.
Kevn Dixn tarafından
Let's start with the no starting issue. You replaced the pump assembly but does the fuel pump get any power? Where and how have you checked?
oldturkey03 tarafından
