After screen replacement home button hits 3/4 times
When I press the button, my iPhone vibrates 3/4 times.
This happened when I replaced my iPhone 7 screen with an original screen.
Can you help me with this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This is most likely due to either the screw on the back of the home button being too tight/loose. If this is not the cause then it is probably a short in the home button.
Bu yanıt yardımcı oldu mu?
I will try to make the screw lose. I let you know!
Not working :(
If that didn't fix it then the home button was damaged or isnt connected right. This can also be caused by using a Chinese replica screen that is not good quality.
Reinstall the home button or try anther home button to have a try.
If you use another home button, it wont work at all. Try using the original home button. If not then there isn't much you can do
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 84
