Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
OEM Front Face Camera Proximity Light Sensor Flex Cable and Display
Recently I had replaced my LCD screen and found I needed to replace my Front Face Camera Proximity Light Sensor Flex Cable because my speaker and front facing camera was no longer working. I purchase one from ebay (bad mistake) and everything but the Ambient Light Sensor worked, so I contacted Apple support and they ran a diagnostics and found that the Sensor failed. Now I am trying to get a refund for this, because not only did the first one fail but the replacement also failed the diagnostic test.
They are trying to tell me that the OEM Front Face Camera Proximity Light Sensor Flex Cable only works with the original LCD display. The issue I see, with them calling it an OEM, is that it does not have Apple's Logo on the cable like to original has.
I would like to know if this is true that the Cable must only be used with original LCD screen, or if I am correct and they are trying to blow smoke up my tail pipe?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
That is false.
I have replaced dozens upon dozens of aftermarket proximity+front camera+ambient light sensors back into OEM Apple screens and they work perfectly fine.
May I ask what model iphone you are repairing?
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
This is for my iPhone 6s . Only thing is this is not an OEM screen. I had to replace the screen because it was shattered. I believe I damaged the original cable when I removed it from the old LCD.
tarafından
Yes that is what I believe happened. Try a new one. Apple is not telling the truth with the statement they have given you.
tarafından
This isn't Apple this is the people on eBay I bought the cable from.
tarafından
I see, i misunderstood. Yes they are not telling the truth. They probably sold you an already defective part.
tarafından
I knew they have been blowing smoke, I just wanted confirmation. I thank you for that confirmation.
tarafından
1 tane daha yorum göster
Yorum Ekle
Contact the customer service for a refund or a new product. The electronic product alway has a warranty period time.
Puan 0
Yorum Ekle
Yanıtını ekle
Michael Miller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 538
