Ana içeriğe geç
The Samsung Powerbot R9250 is identified by model number R9250. It was released in 2018.
power brush is rattling loudly when running
the power bar is making a very loud rattling noise when running. When I take the brush out of the unit, the noise stops
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Since posting my original ANSWER I have also found out that if you use compressed air to blow out the machine there can also be a large reduction is noise if you were getting gear noise. I have found this lasts for about 2 months and then you have to repeat. This reduced noise considerably when I was getting a "gear" sound. Good luck.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have found that fibers or hair get wrapped around the one end of the brush that has the silver ball bearing roller. The wrapping gets so tight and thick the ball bearing roller starts creating a rattle because it cannot roll freely. You need to take a tweezers and razor blade to clean out the ball bearing area.
Mark
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I actually had to reorder a housing unit for my brush due to it melting, what I have found is a little grease on the cover of the round end on the brush will ease the noise, the buildup of hair will cause that loud sound. Hope this helps.
tarafından
What kind of grease do you use?
tarafından
Yorum Ekle
how to go into tst mode???
definitions..
play button  >|
Home Button   house
Corner button  square with box in corner
sequence in service manual?
1..Turn on the main body emergency switch.
2. Press the “play” button to turn it on.
3. Hold down the “cornr” button for 3 seconds.
4. buttons are pressed in the order of  Play -> Home->play->corner
4a  Pictures show home->play->corner ???   WTF
5 test mode is entered
Problem 1 is ,there is no confirmation codes after the sequences are entered, ie after step 2 there is no confirmation  beep or display  etc
Problem 2 should th unit be on a surface or floating ,in the air
My findings.  After step 2, how long or immediately should I do step 3?,  no instructions in service manual
After step 2, unit goes into  5,4,3,2,1,0 and starts to vacuum,  no results when I hold home for 3 seconds?
I don’t know if step 3 was successful, so I don’t know if I’m ready for step 4?
I’ve tried all combos with no success
Does anybody know whow to get this beast into test mode??
Puan 0
Yorum Ekle
Yanıtını ekle
Rick Hoffman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 4,159
