Ana içeriğe geç
Dell Inspiron 11-3147, 11 inçlik bir dizüstü ve tablet hibrit cihazdır. Ekran, elde kullanım sağlamak için arkaya doğru katlanabilir. Ağustos 2015'te Dell tarafından üretilmiştir.
Three beeps upon startup
Does not boot and instead get three beeps. Given three different possible solutions: Chipset Error (North and South bridge error)
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller failure
How would I go about testing which one of those would be causing the issue? The website says to run Dell's diagnostics tool but it won't even boot up far enough for me to access that.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@inlerah start by removing the battery, the AC adapter and the RAM then hold the power button down for a while. Replace the AC adapter and see if it starts up. You also want to try a USB keyboard and see if that makes a difference. If not then I would suggest that you replace the RTC battery first and try to start it up after that. Use this guide Dell Inspiron 11-3147 CMOS Pili Değişimi for that.
Any of this
Gate A20 failure
would require boardlevel repair and for that you need to let us know what exact motherboard your computer has.
Update (10/21/2017)
@inlerah have you tried a different memory module? You do want to rule out that you have a bad module. Your motherboard should have a few numbers silk screened on the board. Just give us those numbers or post some really good pictures of your board with your question. You can use this guide Mevcut bir soruya görsel ekleme to do so.
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Dell Inspiron 11-3147 CMOS Pili Görseli
Kılavuz
Zorluk:
Kolay
10 minutes
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
(Late response, had to wait until drivers of the right size got delivered) So I did this and I got back a "No ram detected" beep code. Where should I be going from here?
Also, I can get you the motherboard type...just need to know where to get that info from.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
William C Ward sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 858
