Ana içeriğe geç
Indecators blinking and operation hanging, no water coming in.
Electrolux care plus esf 6549, indecators blinking and operation hanging, no water coming in. It will keep this over and over. If I fill some ater inside, then t will drain and pump some water inside, but at the same time it will vacume the water out and led diods on 65 c and water in indecators start blinkin! It seems like something hanging. I clean the waterin filter on the house, and testet that the water precure ok. I also put calcuim remover and wait 2 days, but nothing happens more.
Anybody can help with this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
The failure cause was the solenoid water valve.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
MKA this could be an issue with the door latch/switch. Use your multimeter and check the latch for continuity and let us know what you get.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Ok thnk you, I will check that tomorrow and tell you what will happen.
tarafından
Hi, it is the solenoid water valve doesnt react. I ordered replaceent. So the failure has nothing to do with the latch. Thank you.
tarafından
Yorum Ekle
Yanıtını ekle
MKA sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 162
