Ana içeriğe geç
Repair guides and support for carpet cleaners of the upright, steam cleaning, and hot water extraction styles.
I need a special tool to get my shark vacuum apart
The fasteners look like an allen head with a pin in the middle. Looks like you would need an allen wrench with a tiny hole drilled in the middle of it. Any ideas what/where I could get a tool like this?
Bu iyi bir soru mu?
Puan 2
10 Yorum
Thanks for your help!
tarafından
I see what kind of screws they are all I want to know is why!!!!!
tarafından
How in the world would anyone be able to tell you *why* a company used a given type of fastener? Seriously now...
tarafından
The only reason why companies do that is to prevent the "normal Joe" from opening (and fixing) their devices. Companies have done this for years. It absolutely impedes the Right to Repair and that nonsense has got to be stopped!
tarafından
They don't want you to be able to work on them. So in frustration you'll go buy another one.
tarafından
5 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
@toolbag it sounds like you are talking about the tamper resistant Allen screws. It is a security feature that is easily circumventeed wit tool kits like like these. you can get those for Torx as well as many other screw heads.
Bu yanıt yardımcı oldu mu?
Puan 8
12 Yorum:
yes but how do you find out if u need metric or SAE
tarafından
the product is a shark vacuum
tarafından
torx screws are the type
tarafından
@mcgarry there is no difference. The same Torx drivers are used to drive SAE and metric
tarafından
Unfortunately, at least two of the security screws are in a deep and narrow hole that is impossible to reach with the short bits that are commonly sold.
tarafından
7 tane daha yorum göster
Yorum Ekle
These are the right tools to open a shark vacuum cleaner. Yakamoz 11 Pcs Magnetic T6-T40 Torx Head Screw Driver Bit Set Security Tamper Proof Star 6 Point Screwdriver Drill Bits Tools with 1/4 Inch Hex Shank | 3 Inch Length https://www.amazon.com/dp/B078LXZPZ2/ref...
Puan 4
5 Yorum:
Can I use any other tool
tarafından
No, it must be this kind only. These tools are made by different manufacturers.
tarafından
It’s not a star, but I have all those it’s like a flower that has a circle in the middle
tarafından
@wuksgirl the whole in the middle is standard for all tamper proof Torx bit. Take a look on here for common security bits
https://www.reddit.com/r/Tools/comments/...
tarafından
Thank you so much for the link to the Yakamoz tools....just what I needed!
tarafından
Yorum Ekle
I have got the screws out but the unit still seems to be sealed. I gave a new lower hose duct to replace the spilt one but now at a loss as to how to get to it.
Puan 0
4 Yorum:
@lazyboy How did you reach the deep sockets? I have the correct bit, but it doesn’t reach.
tarafından
Were you ever able to get into the unit to replace the hose, Ali?
tarafından
There's screws under the two tiny wheels at the front. You need to pop those off to even see them. I love shark vacuums but as far as cleaning them they couldn't make it more difficult.
tarafından
Curt, thank you so much for your answer. I have been looking for this tool and it's been very frustrating. You made it so easy. Including the link on where to get it it's so appreciated. Thank you so so much!!! Rae Lynn
tarafından
Yorum Ekle
Any body know exactly what size tool to take apart? Have tried every size and can't get it apart!!
Puan 0
1 Yorum:
it must be an issue other than size.
do your bits have a center hole?
are they Torx? Maybe they are Allen bits. THEY MUST BE Torx.
tarafından
Yorum Ekle
Yanıtını ekle
Joe Kaplun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 230
Son 30 gün: 1,206
Her zaman: 95,152
