Ana içeriğe geç
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Soru Tümünü görüntüle
I hear the fan louder
Hi, i have a mid 2010 27"core i7 iMac and although all these years i thought it was fanless, the last few days im noticing that -actually- there is a fan :-) It's not like its making a huge noise, i can only hear it but even so it seem strange because i hadn't noticed it before.
Could it be failing? Before i open the iMac to inspect, can i check it through software perhaps?
Update (10/15/2017)
Does this help in some way?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
Did you change the hard drive?
tarafından
Yes @mayer i did change the drive, why?
tarafından
Sorry for mixing you @mayer, i meant i've added an extra drive, an SSD drive.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
When you chang the hard drive you have to address the Apple priority heat sensor or you will get a run away fan. OWC makes a thermal sensor that you need to install to stop this. Here it is:
https://eshop.macsales.com/item/OWC/DIDI...
Bu yanıt yardımcı oldu mu?
Puan 2
25 Yorum:
What exactly do you mean by "run away fan"? Please describe clearer the issue ;-)
tarafından
The system will go into Safe mode (ramping up the fan to max) when it looses access to any of the thermal detectors within the system.
In this case the Apple custom OEM HD you had in your system offered the needed input, but when you switched out the drive the new drive does not offer that input. Thats why you need the OWC in-line sensor to replace the missing sensor.
tarafından
I see but i have both the Original HDD and the SSD installed!
tarafından
Please tell us with drives you changed
tarafından
I havent changed any drives (sorry for mixing you up before), i only installed an SSD to the original configuration ;-)
tarafından
20 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
genik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 301
