Ana içeriğe geç
ABD modelleri 2012 model yılı aracı olarak satışa sunuldu. İlk modeller dört kapılı sedan veya beş kapılı hatchback gövde seçeneği, 2,0 litrelik DOHC (148 bg) motor, beş ileri manuel veya direksiyondan vites değiştirmeli altı ileri manuel modlu Lineartronic CVT şanzıman içerir.
Key will not release
2013 Subaru Impreza
Key will not release when we shut the engine off. We have already troubleshot several steps. Brake is applied, transmission firmly in park, pushing key inward while turning engine off. Engine shuts off but will not complete cycle so that it can be removed.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Hi don, is the steering wheel locked? Make sure that is can turn a full 360.
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had this issue with my 2016 Impreza. After pulling apart the center console, I figured out what was causing my issue.
To move the shift knob the driver needs to squeeze in the button on the front (blue circle in the picture). This lifts up a rod through the knob (red line in picture) . with the rod up the shift knob can be moved into gear. The rod also presses a button when in park, releasing the key. My issues was the rod was not dropping all the way down and activating the switch. I pulled the rod out and put some light grease on it, hasn’t been a problem since. It was not to much work to get the rod out but I don’t remember exactly how.
Resim
Sorry its so late, maybe this will help someone else
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
If it has a locking steering column, the wheel may be turned too far. Turn the key while jerking the steering wheel back and forth fractionally.
Puan 0
Yorum Ekle
Included with the above recommendations, I depress the brake pedal while removing the key. This might help.
Puan 0
Yorum Ekle
Yanıtını ekle
don fagan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 6,995
