My motor stage broken?
it is saying that my motor stage is broken.....can you help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Not connected to one or all motors. Broken cable, connection not seated correctly, (Push Fit) and connection under arms damaged.
Bu yanıt yardımcı oldu mu?
I have this issue.
Do I really have to go through the process of taking everything apart in order to fix this?
Is this un fix able? also the other thing is it wont turn off with the press of the button, I have to unplug battery to turn it off.
As @https://www.ifixit.com/User/3081968/Mich... pointed out this is one or more motor connection issues.
As per https://www.ifixit.com/User/3695100/swiv... from flight app view, we can find which motor is not connected as it’s red.
For me even though how hard I pushed the connector it did not work properly. The connector was loose. (even though I connected a different motor it did not detect by the motherboard.) I used my multimeter ohms scale which has around 1 Ohm per each of 3 pins. I removed the motor connector and sold it directly to the motherboard :). Did the trick for me and saved some money and time as well.
The motor turn just a little when I first turn on though but then goes to motor stage error
I had the same problem motor stage broken. I unistalled the free flight pro app. Then I reinstalled it and it fixed the motor stage broken. Hope you get the same results
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 5,189
2 Yorum
Same problem, though i suspect its the brushes in the motor( a piece that uses electricity to spin the motor and magnets). And my wire on the leg of the drone broke.
TL gaming tarafından
I have same problem but when I turn it on the perpellar acts like it wants to spin a sec then red-light comes on
James Smart tarafından
