Ana içeriğe geç
Volkswagen Passat'ın B6 ve B7 sürümleri, Alman otomobil üreticisi Volkswagen tarafından üretilen önden motorlu, geniş aile otomobilleridir. Passat'ın B6 serisi 2005 ile 2010 yılları arasında üretilmiş, B7 serisi ise B6 serisinin makyajlanmış hali olarak 2010 ile 2015 yılları arasında üretilmiştir.
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
3 Yorum
this worked for me omg thank you so much
tarafından
Glad it worked, pass it along...
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Push on brake and hit button forgear shifter a couple of times.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
tarafından
It worked for me. Thank you!!
tarafından
Yorum Ekle
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
Puan 0
2 Yorum:
I was programming my remote key fob now the fob is stuck in the ignition
tarafından
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
tarafından
Yorum Ekle
Is there a battery in the fob?
If the five won’t come out of the ignition?
Puan 0
Yorum Ekle
Yanıtını ekle
Darby Rosello sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 73
Her zaman: 22,521
