What can I do with these?
I have these old Altec Lansing computer speakers. I would like to use them but the connects do not match anything on my computers. Any ideas on how I can rewire these (new connectors?) so that they can be plugged into my computer? The only two connectors/wires coming from the speakers are the ones shown.
Thanks
Update November 5,2017
Here are more images as requested by Oldturkey. Thank you Oldturkey for your time and help. You are correct, it is the VS4221. Still not sure if this is going to work but hoping to avoid throwing these speakers away. Also, do not want to spend much money to make these work - I know this is a tricky balance. I have not used a multimeter yet but I wanted to share these images in case this helps. I am a high school teacher so my time to get projects like this done is very limited, but I will try to work on it a little at a time.
Updated November 6; Two More images added below
Bu iyi bir soru mu?
8 Yorum
@teamstarr the yellow connector should be plugged into your subwoofer.
oldturkey03 tarafından
Thanks for the response oldturkey03. I don't have a subwoofer. I was hoping to use these as regular computer speakers. Maybe that won't work but I was wondering if there is a way.
I was thinking that maybe one cord could be rewired to be a plug (for a wall outlet) and the other wire could be rewired to be the audiojack like headphones.
I imagine I am simplifying this way too much but I thought I could learn a little something about how these work if I ask on this site.
StarrDan tarafından
What type of connectors are these? I don't think they are RCA. I am trying to find a way to convert one wire to be the plug (wall plug 120V input) power source and one wire to convert to a 3.5mm headphone jack that can be connected to a smartphone.
It would be even cooler if I could make these bluetooth wireless. Any ideas?
StarrDan tarafından
"convert one wire to be the plug (wall plug 120V input)" not a good idea. I am convinced that your speakers are not meant for120V The subwoofer most likely transforms the voltage to the speakers.
Let me see if I can find anything on this connector. do you have tag on the back of those speakers to give any model number? Looking at your scant picture of the speakers it looks like it might be a Altec Lansing VS4221
3 tane daha yorum göster
