Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
Possible to save MacBook Pro display connector?
Spilled yogurt into the right vents, and it got into the display connector. Logic board and everything else seems fine (yogurt never got there).
Here's some images: https://imgur.com/a/zFL48
What's my best option?
- Clean it with alcohol?
- Order a replacement screen (they go for around 300-400USD)
- Send to apple and PRAY they don't charge me >1000USD (no AppleCare :( )
I tried to turn it on after 48h in rice, and it did work, albeit with weird transparent bar going on and off every few seconds.
Can I test that the screen connector IS the problem?
Any help is greatly appreciated in this time of frustration.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Before you send it to apple at least try plugging it into an exterior monitor. This way you can see if it is the connector going to the screen of your mac or if it is something else.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Can I do it without connecting the macbook screen?
tarafından
If you have an adapter for HDMI such as the lighting cable to HDMI similar to what a person would do if they were going to dock it at a work station. Then use the keys at the top of the keyboard to switch the display.
tarafından
Yeah I got a hyperdrive with HDMI. Thanks, will try it out.
tarafından
Yorum Ekle
Sorry Rice is a myth! It does not work on yogurt only water ;-{ And it only pulls moisture out of the air not wetness like a spill. Besides, just like when you spill your coffee the solids will still be left which can be more harmful concentrated. If you had opened it up sooner you likely would have saved it.
While connectors on this side look bad how does the main logic board connectors and the ribbon cable? If they are clean you have a chance here in just replacing the display assembly. If they look as bad then you may need a new ribbon cable and possibly a new logic board as well. FYI the connector is hidden on the backside of the logic board.
Puan 0
Yorum Ekle
Yanıtını ekle
Austin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,004
