Ana içeriğe geç
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Issues with Home and Power Button
I replaced the glass digitizer. In the process accidentally ripped off the Wifi/Bluetooth antenna. I replaced that and the glass but for some reason when I reassembled everything, the home and power button are not functional (only to turn on but not to wake or sleep). The volume and mute button still work fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
when you ripped of the antenna are you sure you didnt rip anything else off
tarafından
From what I can tell, no nothing else looks out of sorts. Would you like pictures to make sure I'm not over looking anything?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
if the volume buttons work but the power button does not you have likely torn through the cable on the top right hand corner of the iPad when letting the digitiser, it can be replaced following this guide..
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
The home button is not working either. Do you think I may have messed up something there as well? This is my first time attempting to repair an iPad. My apologies.
tarafından
Yorum Ekle
You can also turn off the lock/unlock feature by going to Settings - Display & Brightness - Then turn off Lock/Unlock. This should allow your sleep/wake button to work again.
If you want to actually fix that feature, you will need to replace the power/volume flex as rayeasom mentioned.
Puan 1
Yorum Ekle
Yanıtını ekle
jacob.v4 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 76
