My physical power button is stuck
Hi
Physical power button on my MOTO 360 2nd gen is stuck.
Can anyone help me out
- Sairam
Bu iyi bir soru mu?
Hi
- Sairam
Bu iyi bir soru mu?
id start with a deoxidizer, and spray it into the power button, and try to work it in by pressing the button while it settles.
if that doesnt work, open the watch and verify that the button itself on the board is in tact.
if the button is fully in tact, then remove the button from its opening in the frame, and dremmel the hole a little bit bigger. (less than a milimeter is usually enough)
Bu yanıt yardımcı oldu mu?
I've also had this problem.
I used a pair of needle nose pliers to rotate the button and break up any material that had solidified around the button. And cleaned it with isopropyl alcohol.
do you jave any method to fix this issue
power button stuck
Posted using AnySend MSG 647.9
You have to simply rub with isopropyl alcohol, after that charge the watch power button facing downside, the charger will heat up and help rescuing the power button, then stop charging but don't remove the watch from the dock, let it cool. Then turn the watch again on, I had the same problem. It fixed after doing this.
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 4,690
What do you mean with "it's stuck"? Is it like pressed in? Or you can't press on it?
Alex Niculescu tarafından
Can't press it on Alex
Sairam Karuturi tarafından
