Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Screen replacement - black screen
I smashed my phone and it wouldn’t respond to HDMI output, let me sync with my laptop or make any sort of noise. I bought a £20 replacement screen off eBay and fit the new screen myself. However, the screen wouldn’t display anything but black. The phone would light up and black screen and allowed me to get on it to recover photos - it worked with HDMI, keyboard and made noises etc. I kept trying to get it to display something by removing and reinstalling the new screen...nothing. Then while the screen wasn’t attached to the housing properly it lit up and displayed correctly...until I lifted the screen slightly and GONE. It has done this very intermittently, having displayed the screen for a few seconds every few days. What could be the issue here? Is it the screen or the phone? Do I need to get a better screen or clean the housing? It can’t be the logic board cause it still works, it can’t be the screws because they were put in correctly. The strange thing is that it has displayed a set of blue lines at times. I want to know whether it’s more cost effective to bend the case back and fit the screen or claim on insurance? Thanks a lot
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Cainthat from what I am reading it can be one of two things.
1. It's mostly likely a faulty screen that you purchase. The only way to see if the screen is the issue is to try another working screen. If that doesn't solve your problem then its probably issue number two.
2. Backlight chip could be damaged. This is very common on older devices like the iPhone 6 . This repair would involve soldering and can be expensive. If you have this problem I suggest just using the insurance or get a quote from a local repair shop.
Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
99% sure it's the screen if lifting it up made it work. Where the ribbon is fused to the LCD will have come unbonded.
Puan 0
Yorum Ekle
Yanıtını ekle
Catinhat sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 93
