Ana içeriğe geç
Android smartphone developed by Sony Mobile Communications. Released July 2016, Model #F3213.
Problems in screen and charging
My screen has Black area at prephrary and the brightness is pale, the screen also has black lines at center , another problem, sometime the phope cant charge
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi, did you drop your phone before? Cause there maybe something inside the phone broken.
1. brightness is pale - The screen flex ribbon maybe damaged, or the display was squeezed by something accidentally which break the internal parts in the LCD. In that case you should replace a new screen and here is
2. black lines at center - Check the screen flex cable, see whether it's loosen or not, cause the flex cable maybe loosen which enable only one part of the display shows image.
3. sometime can't charge - check the charge flex cable as well, or reconnect it. It seems the charging port of your phone was damaged.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ansam Rababah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 1,037
