Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Soru Tümünü görüntüle
Beeps 3 times won't boot soldered RAM A1502 MacBook 2015
Beeps 3 times and doesn't not start up. RAM is soldered so I can't re-seat or clean and place it again. Please help, how to solve this problem when the RAM/memory is soldered in the logic board. Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sadly, you need a new logic board. I would go to an Apple Store and give them a piece of my mind!
Do make sure you didn't get your system wet or have big dents in your system.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks, Dan for your answer. The MacBook doesn't has any dent and wasn't wet. Any suggestion which part of chip/component I need to replace in the Logic Board to fix this problem.
If this is a logic board issue, please let me know which component of in logic board do I need to replace. The RAM seems fixed/soldered in place so, by good guess that RAM should be good.
tarafından
Not so simple! Any one of the RAM chips could be bad or the PCH. I can't tell you which chip. Thats why you need a new logic board.
Apple owes you here! If you push they should replace it for minimal cost.
tarafından
Yorum Ekle
Hi Adrian,
As @danj said, you most likely will need a new logic board. If you can get Apple to fix it for free or relatively cheap, go that route! However, if you are unable to get the help you need from them, we sell 3 different models of logic board for your particular machine, depending on which sub model you have. They aren't cheap, but they will fix the problem:
2.7 Ghz Logic Board
2.9 Ghz Logic Board
3.1 Ghz Logic Board
Good luck with the repair!
- Jasen
MacBook Pro 13" Retina (Early 2015) 2.7 GHz Logic Board Görseli
Ürün
$199.99
MacBook Pro 13" Retina (Early 2015) 2.9 GHz Logic Board Görseli
Ürün
$349.99
MacBook Pro 13" Retina (Early 2015) 3.1 GHz Logic Board Görseli
Ürün
$199.99
Puan 2
Yorum Ekle
Yanıtını ekle
Adrian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 4,924
