Why does my mower die when I change throttle from choke to run?
engine dies in run position
Bu iyi bir soru mu?
Bu iyi bir soru mu?
On some engines, the adjustment scew on the side of the carb, is an "air" adjustment, not gas fuel adj. If it's too far out, the carb, is getting too much air and feeding the engine a lean mixture. Choking it blocks air from coming it so getting a richer mixture.
If the mixture is too rich, (as it is fully choked) it will cause the engine to run rough and blow black smoke.
Bu yanıt yardımcı oldu mu?
My craftsman YT4000 riding mower just replaced the fuel pump, but the choke seems to need adjustment. I see a screw but idk what that is exactly . Any suggestions where I can actually not be stuck on full choke only to run
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 1,397
2 Yorum
does it starve out or flood out?
mayer tarafından
Pretty sure its starving out. It starts right back up when I choke it. Problem here is, I replaced the carb. On it when the fuel solenoid went out
It’s done this ever since.
I’m also pretty sure I have everything back in the right place but Im thinking maybe a spring or something popped off.
William tarafından
