Will not run solenoid clicks
I have a 48 volt 2002 club cart the solenoid clicks but the cart doesn't move. When I check the solenoid it has 51 volts on the side coming from the battery. When I turn the key on the other side has 51 volts also. When the peddle is pushed it clicks but doesn't move. Is the solenoid bad? I have replaced the switch on the peddle.
Bu iyi bir soru mu?
