Ana içeriğe geç
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Ethernet card not working
I am unable to connect to the internet via cable (wireless works) and I believe the issue is with the Ethernet card, but I may be wrong. I tried numerous cables (I even tried to use a cable on another computer and it worked, so the issue is not with my internet or the cable). The internet does not work with a cable. Any advise as to what this issue may be, or if the issue is the ethernet card, how I go about replacing it, would be greatly appreciated.
Amanda
Bu iyi bir soru mu?
Puan 1
1 Yorum
+ for clear understandable question ;-)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The ethernet is built into the logic board. You can go with a USB to ethernet dongle or use an airport card. Installing an airport card is a five minute job. It uses a standard AirPort Extreme card. If you give the spped of your machine I can direct you to the installation guide.
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
Thanks for your help Mayer! The processor speed is 1.83 GHz. What do you mean by USB to ethernet dongle? I tried to connect to the internet via a USB cable but that didn't work either.
tarafından
He means to buy one of these.
tarafından
Here's how to install an airport card, and rab is correct on the dongle: iMac Intel 17" AirPort Extreme Replacement
tarafından
Thanks guys for your help. One more question - which would you recommend?
tarafından
Costs are about the same, airport gives you mobility, dongle is faster.
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Amanda C sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 1,576
