Ana içeriğe geç
2003 model yılından 2007 yılına kadar olan birinci nesil Nissan Murano için onarım rehberleri ve destek.
How to change headlights bulb
How to change headlight bulb
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
This should help
https://www.youtube.com/watch?v=8tglvV6S...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
@bexon59 open the front portion of the wheel liner. You should see a white cap with ridges and a tab, open that. Next there should be a silver connector socket with a lighting bolt symbol, pull that off. You should now see the back of the bulb and its clip. Squeeze the clip and pull it back to remove the bulb. This video also not the best, should help you with that.
Puan 1
Yorum Ekle
IF you open the hood of your car there should be a big black screw (somtimes plastic) if you unscrew that you can pull you head light out and disconect the wires. Then you can take off the back cover to the headlight and change the bulb.
Puan 0
4 Yorum:
@tylor_b ah....NO!
tarafından
its that way in my car
tarafından
@tylor_b you have a Nissan Murano?
tarafından
Hes got an old ford escort or some $@$*. My murano is alot more complicated.
tarafından
Yorum Ekle
You can get to it from the inner fender, removing the front wheel well weather protector.
Puan 0
Yorum Ekle
Yanıtını ekle
Verland Laurent sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 17,655
