My laptop is plugged in,charging but actually its stuck at 0%?
My laptop is plugged in and showing its charging but actually its stuck at 0% and only working with power attached
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Most likely you need a new battery. Average life is only around 3 years.
In answer to your comment:
Try running BatteryInfoView available from www.nirsoft.net - this should give you the status of your battery.
And yes, with care, batteries can often last a lot longer than 3 years, particularly if kept cool and minimising discharge/recharge cycles, but in normal regular use you can't really feel hard done by if a battery is fading after 3 years.
For everything there is to know about batteries, check out http://batteryuniversity.com/
Bu yanıt yardımcı oldu mu?
Hmm. I've always wondered what average battery life is... thanks!
Is there a quality battery monitoring program for PCs like Coconut Batter for Macs?
Three years is half of what I am getting on a Mac.
You must test your power adapter in another laptop. If this cant help. Please reinstall Windows. If all this solution doesnt work you must change your battery.
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 6,691
