Ana içeriğe geç
An industrial gas-powered stove by Vulcan.
The commercial stove oven does not stay hot
The Vulcan Gas Stove at work does not stay hot. We are not sure what is causing the stove to not retain heat.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
No answer? How about a more descriptive question?
tarafından
Comes on for 12 minutes goes out pilot light and all
tarafından
Manon First see it is using an igniter or a pilot light.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sounds like a gas pressure issue, make sure the gas lines are not bound or pinched.
The pilot light should not be off or too low, and should be carefully adjusted to have a low burn to ignite the main burners.
When the main burners are on and suddenly go out, it could be an indication of poor flow of either too much gas or too much air, because air is required for the flames to flaming. A quick through cleaning of the burners should do the trick.
Hope that helps
-SF
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Willymae Smith-McNeal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 240
