Ana içeriğe geç
Ear Force PX22, kullanıcının oyun, müzik veya filmlerden gelen sesleri duymasını sağlamanın yanı sıra çeşitli sohbet programları üzerinden iletişim kurmasına da olanak tanıyan bir kulaklıktır. Kulaklık, 2013 yılının Eylül ayında Turtle Beach tarafından piyasaya sürülmüştür.
Replaced broken wire but mic does not work.
My old cat chewed up the audio cable from the headset itself and bit through the wire. I found a 5 wire cable and bought some replacement 3.5mm TRRS jacks and replaced the whole wire and jack with them. The sound works perfectly fine but when i try to test the mic, it doesn't pick up anything. I wired everything up in the way its supposed to be wired up. Ideas anyone?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Clearly, your cat considers that the cat food you provide isn't of sufficient quality ;-)
If you can disassemble the headset you can use a testmeter to check for continuity from the mic itself (or close) right through to the jack and hopefully narrow down the fault. The multi-stranded wire used in headphones is tricky to solder and it's easy to get a tiny solder bridge, or one strand touching where it shouldn't, or it could even be a faulty jack. Also, check there aren't any shorts between any of the T, R, R and S - in fact, try that first! Or maybe the cat chewed somewhere else you didn't notice.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Mc Budder sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 727
