Ana içeriğe geç
2016 yılının sonunda Dell tarafından üretilen 15 inç dizüstü bilgisayar. Dizüstü bilgisayar oldukça özelleştirilebilir olup 7. nesil işlemciler kullanır ve gri plastik bir kasaya sahiptir.
Nothing showing on display ...its black
Some small problem I get inside my laptop,
I tried to reset this but now when I switch on this laptop .....it comes logo of dell and after few minutes the display goes black.... nothing show on display ...
Keyboard is working...
Please give me solution sir.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mallah first connect an external monitor to your computer and see if that displays everything correct. If so then the issue may not be related to your motherboard (CPU/GPU) but it may be a LED issue.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The first thing I'd do is check the thermal paste and dust. A lot of the times when this happens, the cause is related to dust buildup from the system being a couple of years old. In some cases, the problem isn't dust but is related to the thermal paste being dried out.
The first thing to do that is likely to fix the problem is to repaste the CPU and GPU. If you have the dGPU model of this machine, you will also need thermal pads as thermal paste is not sufficient for many laptops with dedicated graphics due to there being a gap.
Here is what you will need:
Thermal pads (dGPU only)
Thermal paste (Artic MX-4)
Puan 2
Yorum Ekle
Yanıtını ekle
Balkrishna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 590
