Ana içeriğe geç
The HP Officejet Pro 8600 Plus is identifiable by its model number: N911g. Released in 2011, the printer can be identified by its brown finish and touchscreen control panel.
Why printer gets stuck trying to print pdf file
In print queue but will not print or delete
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Hi,
Check whether the issue is with the printer or the PDF document. However, many times it has been seen that files are secured with protection due to which it can't be printed. Therefore, if the file is secured then you have to remove print restrictions from it first. For this you can use SysTools PDF Unlocker Tool, it is a simple application which allows you to print secured PDF easily.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you, will try it
tarafından
Yorum Ekle
I guess it's because of the pdf file, it might be secured. You can try to use a platform for editing pdf documents like https://pdfliner.com/ to edit it and save it again, and maybe it will work. I've never used a pdf unlocker tool before, so I don't know much about that, but you can try to use one if you can find them for free online. Another way would be to save it in another format, like jpg, and save it as a picture, but if you have many pages, this will take a while, so consider pdf liner as a quicker option.
Puan 0
Yorum Ekle
Sometimes the PDF reader may cause issues when trying to print. Try using another PDF reader or updating your current one.
Adobe Acrobat Reader: If you're using a different PDF viewer, download and install the latest version of Adobe Acrobat Reader from Adobe's official website.
Try other PDF viewers: You can try other free PDF viewers like Foxit Reader or SwifDoo PDF to see if the issue persists.
If the PDF file still won't print, convert it to an image (like JPG or PNG) and try printing the image.
Puan 0
Yorum Ekle
Yanıtını ekle
Gloria sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 691
