Ana içeriğe geç
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
3d touch and touch id not working..
The touchscreen i.e. 2d touch of my phone works fine but the 3d touch isn’t responding...?
I tried reseting the phone but it just avoids to work..
Even the Touch ID is not working even though the home button works just fine but the finger print isn’t sensed......
I had a screen replacement once.
I would be nice if you help me in finding the problem with it...
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Both the 3D Touch and home button run through the same cable, I would highly suggest trying another screen, as there may be damage in the cable. :-)
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Are you sure as I have problem only with my Touch ID but the home button still works.
tarafından
Yes, I am quite positive, try another screen and let me know, also make sure it’s not a poor copy screen
tarafından
Sure will do that..!
tarafından
Yorum Ekle
I had the same problem, and after i replaced it with the old screen it all worked and I found out that some how the little cable was broken:(
Puan 1
1 Yorum:
I e replaced 2 screens and still can’t get working properly
tarafından
Yorum Ekle
I have 3Dtouch, touchID and force touch not working after I opened My iphone7plus, maybe changing screen I can solve the problem ?
Puan 0
1 Yorum:
I’m pretty sure you have damage one of the flex cable ( the lower one) it’s very easy to . i have done it a few times:( So you you have to be very very very carefull when you open up your phone.
tarafından
Yorum Ekle
I have this problem too with my iPhone 8 Plus, the flex cable doesn’t even seem damaged at all.
Puan 0
3 Yorum:
It is for sure damaged, change backlight and all will be right
tarafından
When I opened my 7 plus I couldn’t see broken flex till I put away backlight screen protection. If you opened your iPhone and from that moment Touch ID and home button doesn’t worked anymore, is for sure the damaged flex. Don’t change any other things, don’t’ change home button, just be very very very careful and change back light. By change only back light your screen will be good as usual. if you change all the screen with a preassebled as GIGA FIXXO ON AMAZON, it will be very easy and secure, but you will not have the original qualiti of apple screen
tarafından
Attention, flex Brocken is not the one you see near the home button!! The flex Brocken is under the protection of the screen. Don’t do it by yourself become is too risky, go to a Chinese or to a Irepair, and say that you want change backlight (15€ Part cost)
tarafından
Yorum Ekle
Yanıtını ekle
Shivam Patil sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 3,361
