Ana içeriğe geç
2000 Kuzey Amerika Uluslararası Otomobil Fuarı'nda 10 Ocak 2000 tarihinde tanıtılan, yeniden tasarlanmış 2001 Dodge Caravan ve 2001 Chrysler Town & Country, Ağustos 2000'de satışa sunulmuştur.
ignition key wont turn
turned off ignition and now key wont tun at all.How do I fix it?
Bu iyi bir soru mu?
Puan 7
12 Yorum
i have done a few things sprayed with pb blaster then graphite powder to still see if this will work..........in the meantime bang it with something the key that is tap with hammer it worked for me today 3 out of 3 times the dealer wants 100 bucks just to do a diagnostic on it?
tarafından
This works for me too! Thanks a lot!!!
tarafından
There's a small pawl at the end of the lock cylinder that hangs up in the steering wheel lock. Pull off the plastic covers on the steering column and spray it with some kind of solvent. Hangs up because the old grease is cold or to stiff. Worked for me.
tarafından
Mine did the same thing this morning. After completely melting down, I asked if we could disconnect the battery. Voila! It started and is running again. He said it looks like a loose connection in the battery cable.
tarafından
I just sprayed wd 40 and tapped the key while in the ignition on an 05 caravan and after the 4th tap of the hammer the key turned perfectly..
tarafından
7 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
In addition to what Andrew said: The key or the lock may have broken or worn to the point of not working. Your dealer can make a factory key if given the VIN number.
Bu yanıt yardımcı oldu mu?
Puan 6
4 Yorum:
Omg thank you so much you just prevented me from having a freaking major panic attack!
tarafından
Tap with a hammer works
tarafından
Yella Gal How did you tap it, did you tap it in or sideways?
tarafından
It work for for a couple days now it’s won’t turn at all.
tarafından
Yorum Ekle
En Yararlı Yanıt
Leave the key in the ignition and tap the end of it with something ( ice scraper works) I use a small hammer I keep in the console, the key will turn.
A locksmith showed me this, works everytime
Puan 15
36 Yorum:
yes it does work but for how long and thank you for that by the way
tarafından
This is a great idea in really work thanks wade
tarafından
Wade . YOU DA MAN. And let us definately not forget to make a shout out to the Awesome locksmith that showed you that. Most are hoping you'll need to call them again , so they won't dare let you in on their secrets
tarafından
Thanks!!! That was awesome. I had to have my van towed home and all I needed was a little hammer.
tarafından
Thank you so much!! How long will this work?
tarafından
31 tane daha yorum göster
Yorum Ekle
One other possible problem is foreign matter in the keyhole. If none of the other suggestions work, you might want to try blowing it out with compressed air. This is usually only problem for people with small children :-)
Puan 3
Yorum Ekle
Sometimes rotating the steering wheel slightly back and forth while wiggling the key will make it turn. You could also try a different key if you have spares. It is improbable that any corrosion would form inside the ignition key cylinder, but places like NAPA make specific lock lubricants like this with graphite powder suspended in them to help free the pins in stubborn locks.
Puan 2
1 Yorum:
Banging the key works because it dislodges the lock pawl on the switch. All of you need to pull off the steering column cover and clean the mechanism.
tarafından
Yorum Ekle
Spray some WD40 in it . insert key few times . then take small hammer and tap key several times while wiggling . This will usually get it to turn . Then you need to replace lock cylinder before it does it to you again .
Puan 1
Yorum Ekle
Yanıtını ekle
tracym602 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 86
Her zaman: 61,412
