Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum:
@michaelbyrd did anything happen to your TV or did this just stat? what have you checkecd? Have you disconnected every input and then just tried one? Checked your menu to see if the input is set right (HDMI, CATV, Composite etc.) Have you tried different inputs? Disconnect your power cord hold the power on button for 60 sec. Then plug your TV in and push and hold the power button. See if that changes anything. If none of that works, you may have to disassemble your TV. Let us know if you are up to it..
oldturkey03 tarafından
