Ana içeriğe geç
Lenovo Essential G560. Bu dizüstü bilgisayar, 15,6 inçlik bir ekrana ve sayısal tuş takımlı tam bir klavyeye sahiptir.
windows failed to start
hi there
when i switch it on it says window failed to start , a recent hardware or software change might be the cause.how do i fix it?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This laptop should have a small button which should be right of the power button for the laptop.
Press that key when the laptop is off. It should kick into the Lenovo one-key recovery.
Try doing a system image recovery there to get windows working again. You may need to wipe the hard drive when prompted which you will lose data using that method.
If the recovery does not work or fail then you may have a faulty hard drive that needs to be replaced and then windows reinstalled on it again.
Edit: You should also be able to boot one key recovery by repeatedly pressing F11 after turning the computer on until you see the Boot menu option screen, select enter bios and look for one key recovery through there. Arrow keys on keyboard to navigate bios, enter key to select an item.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Getrude sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 2,895
