Ana içeriğe geç
29 Eylül 2016'da piyasaya sürülen, LG G5'e benzer, LG V10 akıllı telefonun devamı niteliğinde bir cihazdır. LG V20; F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996 ve VS995 model numaralarıyla ayırt edilebilir. Titan, pembe veya gümüş renk seçenekleri ve 32/64 GB depolama alanı ile mevcuttur.
USB C port replacement
What is involved in replacing a damaged UCB-C port on the LG V20? Actually, I could ask a similar question for my iPhone 6S Lightning port. It's been pointed out that one advantage to "wireless" charging is the reduction of wear on power sockets. With daily use, that would be around 700 plug ins over a two year period, so wonder if this comes up often as an issue, and if so, how to replace a damaged power port.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
heres a video of the disassembly https://www.youtube.com/watch?v=5yC0ROV3.... to do the replacement you will need a hot air station, a soldering iron, flux and some leaded solder
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks. I'll review the teardown you supplied.
tarafından Paylaş
Yorum Ekle
It can in fact be removed and replaced, but you definitely need a hot air rework station, in my opinion. I did find a YouTube video by a very talented person who was able to do it without a hot air rework station. The video is very well done, and I only wish I had his talent and steady hands.
https://www.youtube.com/watch?v=WgXMjRAU...
I took an old broken LG V20 logic board and was successfully able to remove the connector without damaging the board using my rework station. However, due to the heat, the connector that was removed did not survive. The board was fine, and no other SMD parts were moved or appeared damaged. I know that you can purchase the connector itself on Ebay. Be aware that it has both surface mount pins and 6 thru hole pins as well.
Puan 2
Yorum Ekle
Yanıtını ekle
William Vaughan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 5,606
