Ana içeriğe geç
How do I exit DnX mode?
While trying to reboot my tablet I believe I did something wrong and now all it shows is
Entering DnX mode.
Waiting for fastboot command...
How do I exit this mode? I tried holding the power button but it just goes right back to this.
It's a Nextbook Ares 8
Model number NXA8QC116R
Any help would be appreciated.
Bu iyi bir soru mu?
Puan 11
10 Yorum
Same here some times it would turn on and it would be in safe mode and 5 minutes later it would shut down and show its battery charging picture with a ? In it and it would say battery unknown and go back in dnx mode and it seems like every time you put a micro sd card in it goes in dnx mode and if u take it out it will not turn on or work at all until you put the sd card back in right now I am on my computer.
tarafından
Can you download an app for it
tarafından
I have a ares 8 and need help. The TWRP is not working also fastboot commands are denied. las3@nauta.cu
tarafından
Mine still won’t work! I don’t know what to do!
Can someone tell me what to do? I tried everything!
tarafından
Next book ares 8a dnx fastboot mode
tarafından
5 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try this,
- Hold volume up for 15 Seconds,
-While holding volume up, press and hold the power button until tablet turns off
-Release volume up button
-Release Power Button
Bu yanıt yardımcı oldu mu?
Puan 14
12 Yorum:
I did that and it turned off, but I didn't see the Nextbook logo like I usually do when it shutdown and when I turned it back on it still said Entering DnX mode.
tarafından
this didn't work for me
tarafından
Worked on my Lenovo Yoga Book. Thanks!
tarafından
my nextbook is doing the same, when it does this, on a computer, when you plug it in to the computer, it will say that a driver is unavailable. that means that somehow, you'll have to install a driver, which could brick the tablet if not done right.
tarafından
Yay!! It worked on my Ares 10. I wish I could reset to factory, but that is how I ended up with the DNX mode...
tarafından
7 tane daha yorum göster
Yorum Ekle
To get to recovery power on, once nextbook logo appears push and hold volume down. When you select recovery and push power to select, it will come up with a droid and exclamation mark says no command, hold power and push volume up at same time and release. This takes you to menu to wipe cache and reset to factory! Hope this helps!
Puan 2
1 Yorum:
I spent 4 hours looking for this answer , you get a gold star and should move to the head of the class
tarafından
Yorum Ekle
What I did was hold down volume up and power until it goes to a black screen then hold down the volume up and power button while it try to boot you will then see the screen shown below should be a recovery screen use volume up and down to navigate and use the power button to then select reboot system now it’s should then have some yellow text at the bottom and boot up
Resim
Puan 2
Yorum Ekle
So I found out that there's no fixing it,cause the OS has been erased,which means…you'll want a new tablet(unless bricked tablets are your thing)
Puan 1
Yorum Ekle
Worked thank you so much
Puan 1
Yorum Ekle
I get to the Android and exclamation mark with ‘no command’. Continue as instructed. The nextbook powers down and I have to power it back up. It returns to the password screen with no change.
Puan 1
Yorum Ekle
that was all my carot time &&^&@*@!!!!!!!!!!1
Puan 1
Yorum Ekle
Yanıtını ekle
Josh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 23,458
