My phone screen is unresponsive after water damage, can this be fixed?
So i've had this model of phone for a couple of months now and for the second time it has been damaged by water. (This is the second model as the first one also had water damage and was not repairable). It was not completely submerged and was in the water for less than a second but water still managed to get inside. I took everything out, dried it, used rice and restarted it a few times and the phone still manages to turn on and function almost normally. However, my screen is unresponsive despite the phone still working. It has never been dropped, scratched or anything else but i have files on there that i need and i'd rather not get a completely new model again as my make of phone is no longer available near me.
Also, the screen was bright red and blurry the first time i turned it on after i had dried it. Just over 24 hours later (now) it's fine apart from the screen issue. So what i'd like to know is:
What could the problem be?
Can it be fixed?
If not, how can i transfer files from one phone to another if the touch screen is unresponsive?
Thank you, any information would be appreciated.
Bu iyi bir soru mu?
5 Yorum
My Samsung a71 got slightly wet at the bottom where the charging port is I put it in rice for two days it's working but touch screen is unresponsive what do I
camhotnes tarafından
I have se same phone, and same thing happened. what was the outcome of your problem?
Charlene Cornelissen tarafından
Hi. this is my current problem… I’m not bothered about having to replace the phone… but really don’t want to lose stuff.. What are my options to try and save the phone contents and where do i go to get this help? Thanks in advance
S harvey tarafından
Screen problems
Wahab Ali tarafından
@wahabali You will have much better luck getting help if you start your own question with information on the device you're having problems with and a good description of what's wrong.
Jerry Wheeler tarafından
