My stylus got stuck in my Samsung Chromebook plus
After my pen broke I fixed it with tape but when I put it back in it got stuck. I tried getting it out but that put it in farther
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hey dude... same thing just happened to me. Here's how I got it out.
1) Own a tiny screwdriver that can be used on the back panel of the computer
2) Remove all 8 screws from the back plate
3) You'll see that there is small plastic holder that the pen sits in
4) Carefully remove the screws that keeps this plastic holder in place
5) Remove the pen
6) Replace all the screws
7) Don't do that again!
Bu yanıt yardımcı oldu mu?
Thanks so much it worked
There's a ribbon cable that needs to be removed, also the screws have to be reinserted a certain way otherwise the case will slightly bulge
i don't really have any way to unscrew or remove the back panel, are there any videos on that??
Hi, I have a Samsung notebook and it looks like there's no back panel.
im not a very techy person so I'm going to try the screwdriver thing. Is there anything that i should be really careful not to touch/mess with?
I'm not quite sure if I understand what you mean but as far as I think I understood is that you put a pen on to a jack or your computer and it snapped then you pushed it further in to the jack? If I got that right then I suggest getting a screw and a screwdriver (if wanted) and screw the pen out of the jack. I had this problem but it wasn't a pen it was a headphone jack it snapped in the phone's headphone jack! Hope this works if this isn't the problem your having please explain to me what your problem is again?
Samsung Chromebooks (Basic, Plus, and Pro) have styluses that go into the body of the machine, like the old Palm Pilots and other PDAs, with a little clicky tip on one end, like a regular pen, that likes to break off. If that happens, the stylus gets stuck in the machine, like if you put half a stylus into one of the old pdas...
Those Styluses aren't super easy to get out of those chromebooks, especially when they break like that.... @slinkliechan is on to something, try taking an M4 or an M5 screw (whichever is VERY slightly larger than the body of the stylus, so it'll only bite the inside), drive it into the body of the stylus. and very carefully pull it out of the chromebook. Then, replace that stylus, they're like $25usd right now on most parts sources.
Hello, if you are still trying to fix it or don’t own an M4 or an M5 screw, I have an alternative way, get super glue and put it around the broken part, then put the smaller part in, then wait 40 seconds. Take it out, then you have your stylus back! I recommend that you get a new stylus because it might break off again.
hoojojeownniwaibeivdyu
Easy peesy way. Get your power screwdriver and the tiniest bit you have and drill a hole as far as you can. Then (ever so gently) tap the reverse drive over and over and over till it's as far out as you can get it. Then gently tap the edge of the chromebook on the floor until the broken piece comes out slightly and then ever so carefully, extract that sucker. Done.
I prised mine out very easily with a 16mm veneer pin. Quite surprised it worked so easily.
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 32
Her zaman: 9,622
1 Yorum
I found an easier way I grabbed a tack stuck it in the hole and it popped right out.
Amber Appel tarafından
