Ana içeriğe geç
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 Soru Tümünü görüntüle
Why can't I shift 2003 Cav manual transmission into any gear?
2003 Cavalier with manual transmission lost ability to shift while shifting from 1st to 2nd. The shifter feels loose now and I am unable to shift into any gear. I am able to move the shifter into the correct positions, but feels loose- like something (shifter linkage?) has become disconnected or broken, and does not move manual transmission into any gear at all. What do you think? Where can I find a free diagram to isolate suspected components?
Bu iyi bir soru mu?
Puan 0
2 Yorum
I am currently having this exact problem. The link to the solution is broken. Any info would be greatly appreciated
tarafından
Have the same issue but linkage works fine can't go into gear with or without clutch meaning free play like linkage is broke but on the trans where the linkage is hook to moves freely thanks for any advice
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you've dropped the pivot bolt. Here's how to fix it: http://www.dmctalk.com/showthread.php?t=...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
The link will not load
tarafından
Yorum Ekle
Hi @sarahphill66113
Here's the parts diagram for a 2003 Chev Cavalier manual transmission shift control that may help
Puan 1
Yorum Ekle
Yanıtını ekle
Diver Down sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 4,502
