Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
20 Soru Tümünü görüntüle
Phone won't turn on at all!
Hi guys, I'm having some big issues with my old iPhone 5. First off I did a lock button and home button reset and it brought it to a new start up menu where I had to connect to wifi and restart the phone as I 'restarted it' which was unusual. But the device couldn't find my sim so it wouldn't start. So I taken matters into my own hands and as the phone got soap in it once I thought the insides could be hot. So i got a hair dryer and tried to dry the damp looking phone for 3 minutes. I then went to turn the phone on and it now won't turn on at all! Any help for what I could of broken?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It is almost impossible to know the issue based on the information, as so many parts could have been compromised. I would start with getting an amp meter, so you can see if the phone is drawing any power, to try and focus in on what is causing the problem. If the phone is drawing a normal amount of power (around 1 amp), then it would point towards some kind of display issue (bad screen, bad backlight, damaged fpc connector etc), but if it's not drawing any power or minimal power, it would likely be an issue with the board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi David, thanks for your input I have a multi meter at work so I’ll give it a try! Where would you place the amp meters rods on the phone to see where the power is coming from? The screen was definitely damaged I need to place a new one on it as well so I’m hoping that’s the case! If the board is broken then I take it that the phone is dead? Is there any way to retrieve the data of it? I appreciate all of this help thank you!
Puan 0
1 Yorum:
so you said you got soap in it and only dried it with a hair dryer. you will need to check the board for damage also just drying it wont help. it will need cleaned in an ultrasonic cleaner. any number of things on the board could be the cause of it not turning on. so take the board out and have a look over it. even take photos and post them as it could just be a cap has blown
tarafından
Yorum Ekle
Hi guys, just to let you know the phone works now! I placed a new screen on it and left it on charge and it just turned on, the flex cable was damaged cheers for all of your input. To get the sim to work I heated up the sim tray which has soap and then blew the phone out with an air gun... Rightly or wrongly doing so its fixed!!
Puan 0
Yorum Ekle
Yanıtını ekle
rhys sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 65
