Can't connect printer to wifi
I have an Epson XP-245 printer, purchased a few months ago. Until recently, it has worked perfectly, but now wifi connection is cut and I am unable to re-establish connection. I have followed the instructions in the manual several times. I have switched off/on the router, and pressed the WPS button (several times in last few days). When I press the printer wifi button, the red and green LEDs flash alternately, but the result is always the same: finally, only red light on and no connection. Can you help?
Bu iyi bir soru mu?
Hey Suzy. In this case, especially if the WiFi cut suddenly, my guess is that there is a hardware or software problem with the printer. In the case of software, try to update or restart your printer. In the case of hardware, my suggestion would be to use a wired connection to your computer or router instead of trying to repair it.
Sinsiter tarafından
