Ana içeriğe geç
Indesit bulaşık makineleri için tamir bilgileri.
Whirlpool Dishwasher stops after filling with water
My dishwasher stops running after it brings hot water in at the very beginning. Sometimes, it will start and stop various times (I suppose, continuing on through consecutive stages, but I can't be sure what it's actually doing because it rarely ends with clean dishes) across many hours. Other times, it never gets past this initial intro stage.
A few times in the past, I had success at cutting the power at the breaker, and then it tended to work perfectly for a handful of times afterwards before it would start acting up again. This last time I tried to cut breaker, however, was unsuccessful, and now it won't get past that first stage (which I always have to hit cancel to drain the water, which luckily still works every time). --Funny but not, I broke the breaker switch flipping it too many times, so I had to replace that today.--
By the way, it opens the soap tab after 5 or 10 minutes, even if it's not running/washing. So, some aspects of the "wash" cycle are working, I guess.
All panel lights are working and displaying on top.
Whirlpool Gold
Model: Wdt710paym
Only 3 years old.
Thanks for any help!
Bu iyi bir soru mu?
Puan 23
21 Yorum
Could you try referring to your user manual and see if it is in the troubleshooting area?
tarafından
My dishwasher would not start, the buttons all seemed to work except the start button. I found online that the most common issue is the door latch - it was $17 plus shipping and tax - replaced it - still broke. Found error codes to indicate a stuck button (should've done that first) So I ordered what I thought was the touch panel - it was just the plastic parts and not the 2 little computer boards underneath. So I pulled the control panel on my dw apart - there are little buttons on those boards - how they work is kind of annoying. There is a tiny copper disk that is shaped like a concave lens. The shape acts as a spring so if the little copper disk (under the start button) wears out or flattens out it will NOT work and the error code indicates a "stuck" button. I replaced the little copper disk with one from a button I know we wouldn't use (was "top rack wash" only) and left that button not working. This allowed the start button to function. Beware - the parts are tiny! I used tweezers to mess with it.
tarafından
btw - in my post above I have a whirlpool gold series dishwasher model # wdt710paym6
tarafından
I read thru the solutions and pushing the door firmer solved my problem and engaged the motor. I recommend others try that before ordering motor parts. Until I did that it would just fill up with water and drain without washing the dishes. This has been the easiest fix ever. Thanks for this forum!
tarafından
this worked, thx so much! saved me time and money
tarafından
16 tane daha yorum göster
Yorum Ekle
28 Cevap
Filtre ölçütü:
Seçilen Çözüm
Don't go with the control board on this! It seems like that is what it should be, but in most cases - replacing the wash motor is actually the answer. Especially in the cases where the dishwasher fills, soap dispenser opens, etc...
For whatever reason - Whirlpool did not include any type of motor feedback circuit on these models. The motor has a weak/poor internal connection, and is not running when it is under a load(i.e. - full of water). Because there is no feedback circuit - the control board is still sending the voltage down, and 'thinks' that the wash motor is running. It will go through all of the other cycle functions normally, but you will obviously have dirty dishes at the end of the cycle. These cycles go for 3+ hours too -
The part that I am recommending in this case is called the 'Sump & Motor Assy'. You will also need a complete model number when you find this part! You are missing the final digit in the model number provided. Open the door and look inside at the edge of the tub on the right or left-hand side. The final digit will be a number - 0,1,2,3,4,5, or 6. These are all different versions of the same model, and the part number will vary, depending on the version. Hope this helps -
Bu yanıt yardımcı oldu mu?
Puan 26
25 Yorum:
Boyd, I am having a similar problem as them. I will start a load and it will fill with water. Water doesn't seem to heat up in the bottom. Washer never runs. After 1 hour (appx) it drains then adds more water. RUNS for about 5 minutes. Then drains and refills. Then it ran for another 10-15 minutes before I opened the door to see what was going on inside. The bottom was spinning. Could not tell if the top was spinning or not, it may have been (or the bottom spun it).
Here are my thoughts:
- is the heating element bad? After 5 minutes of water sitting in the bottom it wasn't hot to the touch
- does it need to sense hot water to start the wash cycle?
- if it doesn't start the wash cycle after (appx) 1 hour does it just move along to rinse (or start the wash)?
We haven't been using this for months but I am ready to get it fixed. Troubleshooting is always the hardest part.
Symptoms were: dishes not clean, long loads, soap residue on inside of front door.
tarafından
Hi Dan -
Are there any flashing lights happening on the console after the wash cycle has "completed"? If this is the same/similar model, and the heat circuit is not functioning - you should see a light flashing several times in succession when the cycle is over. It may stop early in that case as well.
If the lower spray arm is turning, the wash motor is definitely running. There are a few possibilities depending on the scenario.
1. Does the drain go down through the floor or go over to attach to the sink? Floor drains are ALWAYS SUSPECT to siphon water out slowly = all of your symptoms. Way to test: Repeat this 2-3 times if necessary. Start cycle and let it fill. Open door. 'Cancel/Drain' - close the door. Let the drain pump run for 10-15 seconds at least. Open door. Watch the water level in tub for 5-10 min. Should not move.
2. Inlet water temp should be in the range of 90-120 degrees coming in.
3. Restricted water flow coming to the unit, or a faulty inlet valve.
4. Weak/faulty wash motor.
tarafından
When I was checking for the part on whirlpool; kitchen aid and frigidaire also came up. I would assume it’s probably the same issue - if in fact the dish washer “acts” like it’s running the cycle and completes the cycle but the dishes are still dirty. I also opened the door about 1/2 hr into the cycle to see that there was warm water in the tub with humidity but nothing was spraying or splashing.
Granted your dishwasher is 10 years old so depending on how much you want to sink into for repairs, you may be better off just getting a new one for around $400. I took a gamble and ripped mine apart with a YouTube video (I also cleaned the sensors) and the material was only $120. Kinda up to you what your next steps are and how much patience you have with assembly. Best of luck and report back with what you decided to do. It always helps he next person searching :)
tarafından
Boyd, I went ahead and ordered the sump and motor assembly from repairclinic and this did the trick! Thank you for helping me get it solved. The fix was super easy after watching a repair video on youtube. Only took me about 20 mins.
Dan
tarafından
It looks like the latch could be the problem and not the motor assembly. I had the same issue as others above (filling with water, draining but not washing) and it was the door not closing properly because of the darn latch. Just hold the door firmly against the latch and it should begin to wash.
tarafından
20 tane daha yorum göster
Yorum Ekle
Putting this here hoping it may help someone not waste their money on a pump that won’t help.
All the people who are stating it’s the latch are correct, my whirlpool gold series washer started doing this and after pulling it apart I’ve come to the conclusion that what’s happening is the metal lock tab is wearing down the plastic latch in the door and it’s no longer able to depress the latch far enough down to reset the mechanism.
You can tell if this is the case on your by the ways it sounds when closing, mine started making a light thud noise, it is supposed to make a louder clack noise.
Two ways to solve this is to either buy the latch piece and install (easy peezy like half hour tops) or be cheap like me and get something small (I’m using a small star screwdriver, the kind of point used on eye glasses screw or slightly bigger) and push in lightly on the side of the latch and you should hear a click then close door and listen for the clack and start washing
Update (11/22/2018)
Forgot my model, it’s WDT720PADB2, latch for it is like $25 cad
Displays and allows user input for your dishwasher's functions and settings. Görseli
Ürün
Whirlpool Control Panel - W10815487
$151.99
Puan 19
28 Yorum:
Same problem.. will definitely try latch first after reading all of the IDENTICAL complaints... Just amazes me .. Of course they wanna sell you $125 parts instead of a recall, shoooot.. Thanks again! Will update post door rigging ;) PS - Whirlpool
tarafından
Tyler - Thank you! Yes!! I just tried the tiny screwdriver and the latch mechanism snapped very loudly, I've never heard that sound before! Can't wait to test it tonight ;-)
tarafından
By pressing down on the latch, it clicked and made the door handle lock. Did I do the right thing? The door won't close unless I squeeze the handle and undo the click. And still, the washer doesn't work after closing the door.
tarafından
@capps I’m not familiar with that issue as the issue I posted is the only one I’ve had to deal with so far, so you may have an issue that is possibly different than mine.
I just want to let it be known I am a mechanic and not an appliance repairman, so use this info at your own risk.
If you want to you could take off the outer door panel by removing the screws around the inner perimeter and either lifting a little up and out or swinging out, etc. Behind that is electronics that are powered so you may want to turn the breaker off to remove the power.
Near the top of the inside will be the latch, it could be buried behind what I’m going to assume is a reinforcement panel. Get the latch out and inspect it to see if there’s anything wrong or off and then try to operate it. You may be able to see if there is an issue with the latch or not.
I also took my digital multimeter and checked for continuity through the wires by touching the probes one to each side of the connector on the latch...
tarafından
And then operating the latch mechanism to see if it was able to have a signal sent through the wires and be received on the other side and then back to other probe.
This may not fix your issue but it does rule it out and now know to look elsewhere for your issue
tarafından
23 tane daha yorum göster
Yorum Ekle
This was exactly the problem with our Whirlpool dishwasher. I bought the sump and assy from sears parts website and boom it works again. Same issue where it would load with water and just sit for hours sometimes before it would drain but it never would run the cycle in between with the sprayer(s). Didn’t matter what cycle I placed. I tried unplugging it, plugging it back in and no dice. So thanks for the answe cause a $750 dishwasher we bought and I replaced the piece at $120 instead of buying another dishwasher!
Puan 3
Yorum Ekle
OMG!!! The latch was the issue with mine too!! Yesterday I took the entire thing apart and manually checked if the motor was working, then the pump, then the drain, I even connected the motor, pump, etc. to electricity individually to make sure they weren't damaged and to my surprise they were all working. I thought it could be a fuse, but the machine was turning on, etc. fine. My only options was a technician, new machine or personally changing the motor assembly or the panel...none of these were good options.
Long story short, after putting the machine back together I found this site today and read about the latch issue and said to myself, what the heck, let me see if by closing the door like they say here the machine will actually start washing (it was filling with water and draining before but not washing). So I held up the door firmly against the latch and voila!!! it started washing again. Thank you! Thank you! I just now need to figure out how to permanently fix that %#*@ latch...
Puan 3
4 Yorum:
Yes! I've found that if I **gently** push down on the tab that goes into the door latch it seems to work fine for a while. Knock wood haha
tarafından
Thank you, thank you, thank you! It is the latch, free fix...
tarafından
Does any one have pics you can share where the latch is? And what to take apart I only have a small latch on the inside and a flat handle out side to release the latch I'm confused 😕 by the latch option
tarafından
@brandeeotoole
What is the model number of your dishwasher?
tarafından
Yorum Ekle
For anyone tracking this megathread, I have a new unique solution to this issue that I haven’t seen ANYWHERE else. For the record, here were my symptoms:
  • Would fill with water just fine
  • Clicking noises would occur but circulation pump would never turn on
  • Would drain just fine and fill again, with no circulation pump running at all at any point
  • Upon opening, no spinning or spraying at all, lots of steam.
  • Randomly would work and not work, didn’t have any particular pattern
  • Seemed to work better after power was cut for a while as others have said. Never played the circuit breaker game, but did observe this from working on it repeatedly with the power off.
Here were the solutions I tried:
  • Replaced the heating element after getting 7-1 the first time. New element has consistently ohmed right.
  • Replaced the control board. This changed my codes from 7-1, 7-2 consistently to just 6-4 or nothing at all when doing a full diagnostic run.
  • Replaced the circulation pump. Measured ohms in the megaohm territory between 120V terminals on both the old and new pump, and neither terminal shorted to ground on old or new.
After that last repair, here’s what happened:
  • Ran diagnostic while I had the machine pulled out after installing new circulation pump. WORKED GREAT!
  • Pushed machine back in, cycle ran to completion, hooray.
  • About 8 hours later loaded washer again, started cycle, THE ISSUE CAME BACK WITH THE CLICKING!
At wits end, I pulled the washer out. Again. During a cycle where it was in the click state, I pushed my AC voltmeter probe into the connector that goes into the circulation pump - see image.
Resim
IMMEDIATELY THE PUMP TURNED ON! The connector was very slightly LOOSE!
Looking around I noticed that the metal water inlet hose was very close to that connector and would have potentially touched it when pushed back into the cabinet. I suspect the cause of it working intermittently was either the spark jumping the gap and jostling the connector just right to have it run for a cycle or something like that. The pump does lurch around a little when it kicks on since it’s just held there by a bunch of rubber grommets and such.
Using some trusty duck tape, I tied it away from that area completely and used a little more duck tape to secure the connector in place a little better. Obviously this connector is extremely substandard and should have never been used for such a critical 120V circuit on this machine. If it happens again I’m soldering the terminals directly onto the wires because I’m so tired of this crap. Definitely give this a try if you’re having the clicking problem and the latch solutions get you nowhere!
Puan 3
2 Yorum:
I have a better solution. I bought a new dishwasher. Not a Whirlpool. A Samsung. Much better cleaning than than the Whirlpool. I have now realized that when someone rates an appliance, they rate it when it is brand new. Not after 4 years.
tarafından
I have no words for your help! this was my issue as well. Fixed the contacts to be tighter and its working since!
tarafından
Yorum Ekle
I want to tell this crazy answer. My whirlpool would fill and drain, but not wash. I was getting ready to replace the pump and motor assembly. There isn't much room to work under the machine so I thought I would try one last thing. I removed the lower dish rack, lower spray arm and filters, then I wacked the sump assembly a couple of times. I reassembled the machine, started a cycle and guess what, it started to work just fine.
Puan 2
3 Yorum:
Mine would work off and on (intermittently) so I can't say whether this is a fix all or not.
tarafından
It's been 3 months now and my machine is still working great
tarafından
Adding to this crazy answer, I jammed a flexible plastic knife into the water inlet at the bottom of the dishwasher. It worked! So far so good.
tarafından
Yorum Ekle
The issue here is 100% the circulation pump. Watch this video to see the internal workings of the pump and why it’s failing. https://www.youtube.com/watch?v=Ki68BVU-...
I replaced the door latch first. Sometimes the wash cycle would start, and sometimes it wouldn’t. I pulled the dishwasher out, and could hear clicking coming from the circulation pump at the base. After tapping the pump with a screwdriver, it would start up. The issue is the graphite bushing inside of the pump wearing out, and the internal shaft of the pump gets in a bind because it’s resting on the inside wall of the motor and won’t start up on its own. A little shaking or tapping will help it get started. The more the bushing wears, the harder time it has starting up.
I ordered a new pump, removed the old and installed the new. Super simple install, which took about 30 mins. After doing this, I broke the old circulation pump down as shown in the video, and my bushing had ovaled out and there was a ton of wear on the shaft. 100% success with the dishwasher since.
Puan 2
3 Yorum:
Exactly the same for me. Don't replace the pump: that'll cost $50 and the problem will likely recur. FOLLOW THE VIDEO.
I got the lower bearing out with a dental pick. I purchased “uxcell 685 Plastic Bearings 5x11x3mm Glass Ball Nylon Cage 685 Bearings 5pcs” from [AMZN]… < $9. These bearings are only 1mm high, so they actually fit beautifully *underneath* the black plastic (silicone?) retainer rings. The ID is a nice fit on the shaft, with insignificant play.
For the bottom bearing, a thin ring of aluminum HVAC tape (“mastic sealant”; super sticky; not duct tape) brought the OD up to being snug. For the upper bearing, the OD of 11mm was rattling around in a hole of about 14mm; a *careful* application of JB Weld solved this and centered it firmly. When I reassembled, I solved the "vertical play" with two more bearings stacked on top of the magnet to keep it away from the lid.
The dishwasher has now completed several cycles with no issues.
tarafından
And, by the way, Mike E: Thank you!!! :D
tarafından
Ben, is that dishwasher still running?
tarafından
Yorum Ekle
I have had the exact same problem with my whirlpool gold dishwasher. It would fill with water, run through the first cycle, pop open the soap dispenser, then just sit... For hours. I replaced the door latch, then the interface (button circuit board), neither of those parts fixed it. It seemed like it had something to do with the house shifting with different seasons, and if I twisted the door Just right, it would catch again and complete all cycles. The other day I loosened the 2 screws that held it tight to the bottom of the countertop and it has worked perfectly since. My theory is that the tabs attaching to the countertop were holding the latch tongue at an angle which wasn't making good contact in the door latch switch. So now it's somewhat free floating. Maybe worth a try!
Puan 1
9 Yorum:
@celia omg...I have Had several service calls and each time they replace the sump & motor assy...and it is exactly what you say..something with this %#*@ door switch...if I slam it shut it works..if I tilt It just right it works...do I know How to repair the issue..no but you have helped me more than you know....I knew It wasn’t that darn motor. I knew It was electrical and not the darn pump. Thank you for your input..you are correct!!!!
tarafından
@mcassell yes! It's a problem with the actuator not making good contact with the switch. I don't know how to permanently fix it, but now I know for sure it's not the pump motor assembly or the timer mechanism. I've found when it gets to that point and won't continue, if I push in and down at the center of the handle it usually catches and continues all the way to clean and dry dishes! Really puzzling, it's a shame because it's a great dishwasher.
tarafından
I have the same problem. Replaced motor and assembly, and control board, did not fix the problem. Just looked at the latch and it looks like it’s latching properly. What is my next step? Can somebody help?
tarafından
I finally broke down and got guy out there. He found that is was loose wire. Rechecked everything and it works perfectly. Hope that helps.
tarafından
yes thank you was driving mecrazy as everything seem to work great except would not wash as i found this site and sure enough that what it was latch swith was not catching right.so i had to adjt the door on the one side
tarafından
4 tane daha yorum göster
Yorum Ekle
Having a similar issue. We could get ours to run on rinse and light wash, so I knew both pump motors were fine. I was wondering if there was some sensor that was bad that would not allow it to run in normal or express wash mode. Figured I would give the latch a try before tearing into it. I checked it out and it seemed like it wasn't quite seating. The metal hoop seamed greasy and there was some gunk in the receiver on the door. I cleaned them up and it definitely seated/grabbed better when I closed the door. Selected normal wash and sure enough it ran! Hey KitchenAid, if you're not going to put an electronic link for a fully seated latch then make it so it won't run at all... Thanks everyone.
Puan 1
Yorum Ekle
Same Issue — water fills, but no motor at wash cycle. Took the connector off the motor and verified 120vac. When I plugged it back on the motor, noticed it seemed loose - so took needle nose and compressed the connector together so it would fit tighter — and it fixed it. It is a cheap plastic connector that evidently can wear and lose connection to the pins on the motor.
Puan 1
4 Yorum:
I have the same problem. Mine fills with water but won't run the wash cycle. How do you take the connector off of the motor? Thank you in advance
tarafından
I have the same issue with my whirlpool gold series. Inserted a small screwdriver to reset the latch, it started to work normal right away, next step is to replace the latch, but at least I Know what the solution is. Thank you so much.
tarafından
i woke up one night and could smell plastic burning. i checked the dishwasher and a lid and fallen through onto the heating element and melted. i believe it has burned it out but my dishwasher will run water in but won't wash or heat the water. i can hear it clicking trying to go through cycles but it doesn't wash. it will only run water and when i hit cancel it spins the water out. i believe it goes through the cycles because the soap despencer was open but the dishes had not been washed. so could it possibly be the heating element make it not run?
tarafından
Mine is a Whirlpool WDF530PLYW0 dishwasher. Forget the schematic--it's all in French! Symptoms: Fills with water, waits about 1 minute, pumps water out, then tries to run the wash cycle while dry. Trying to run dry probably killed the motor pump. It was full of granular black debris from what looked like its own ceramic parts. No error lights. Replacing the motor pump worked for 1-2 washes and then back to the same issue. Replacing the main board did nothing. I forced it to work by allowing it to drain and manually adding water. After that it tried to run the motor pump but It didn't wash. It stopped, filled a few times in short bursts and sat there clicking every few minutes-like a timer was clicking through steps in the cycle. I figured it was expecting that motor pump to work and it wasn't, so I reached under and jiggled the wire harness connected to the pump motor--BINGO! It started washing! The wire harness (a small white plug-like connector with 2 blue wires) simply wasn't making contact inside.
tarafından
Yorum Ekle
Definitely the pump and motor assembly. Easy to replace too. I didn’t even have to remove the washer. Everything can be done from inside and underneath. YouTube it.
My my machine was filling with water but it didn’t circulate the water. It did complete the cycle(even the detergent door opened), but it wasn’t washing dishes.
The part is a little pricey. $120-$170 depending on the model. But better than $400-$800 to replace. Plus easier than. Installing a new unit.
Thanks for the post!
Puan 1
Yorum Ekle
Solved—I hope. So I had the same issues with my Whirlpool WDF510PAYSA model dishwasher. After trying to recycle the power and fiddling with the latch switch, it still would only fill and drain, but not wash. I finally pulled it out (while still hooked up) and checked the pump connections. I had noticed that after filling, it sounded the circulation pump was trying to work—slight pulsing hum. I then hit the Start button, and once the fill cycle ended, I grabbed the pump by hand and twisted and shook it in its “flexible” mount. Either a connection was loose or debris was lodged inside—either way it sprung to life and began pumping water through the spray bars. Problem apparently solved! I don’t recommend working on the machine with the power on, obviously…
Detects when the dishwasher door is closed. Görseli
Ürün
Whirlpool Dishwasher Door Switch - WPW10274880
$45.99
Puan 1
1 Yorum:
Many thanks to all. I had the same problem with my 2 1/2 year old Whirlpool. Pulled the bottom access panel, reached in and pushed the cheap connector onto the circulation pump. I felt it move a little and click. Problem solved.
tarafından
Yorum Ekle
I’m having the same problem we have replaced the water intake valve the sump and motor assembly and nothing. It will start fill with water and then stop then drain fill stop.
Puan 0
2 Yorum:
Hi! Same here. Moments ago, I finished replacing the water intake valve and was so disappointed because it's still not working. I tried the suggestions above about the door latch, and that doesn't seem to be the problem either. My next step would be to replace the sump and motor assembly (just because that seems to have worked for some folks.).
Did you figure out the problem with yours? I ran the diagnostics and got a few codes: 6-2, 7-1, and 5-1. 7-1 is the heating element which hasn't been working for ages. 5-1 is the door spring, which also broke a long time ago. So, I think the problem must be 6-2, related to the water intake.
tarafından
What model do you have and how did you get diagnostic codes? Do you need a machine like one you would use for a car?
tarafından
Yorum Ekle
Does it pop open the soap dispenser door, then just sit there?
That's what mine does. If I slightly lift and twist the door I can get it to continue and properly complete the cycle. I think it has something to do with the latch not making good contact inside the door.
Puan 0
1 Yorum:
Omgosh🤯it WAS the door latch!!! I had all the same problems, would fill but not run through the cycles, would eventually drain and dishes were left dirty. Would heat up just fine and there was steam. Just took a flathead screwdriver and pushed in the white tab on the door latch until it made a loud click. Closed the do, ran all the cycles just fine👍🏼. A million thanks to everyone who’s contributed to this thread🙌🏼!!!
tarafından
Yorum Ekle
Not quite the soap will open and it will sound like it’s starting up to clean then die out then try again then stop.  At the end water will be in the dishes but they won’t be cleaned. I put bowls on the top rack they are full of water at the end.
Puan 0
4 Yorum:
Does it sound like the spinner is actually spinning inside after it fills with water?
tarafından
Hi Donna, I'm having this problem and no, the spinners are not moving at all. I can hear occasional clicks, as though the cycle stages are progressing. The water fills, float valve makes the tick sound, soap pops out, but then silence. Do you have any ideas?
Thanks!
tarafından
Mine is doing the same thing Janna. It will start the cycle, fill and swish around and then drain. I can hear clicks also, but then nothing. When the cycle is complete, the dishes are still soaking wet and not clean. It's not hot and steamy like it used to be when I opened it.
tarafından
Mine is roughly doing the same thing. I replaced the fill valve because the tenants said there wasn't any water at first but I don't think that was the problem. I tried playing with the latch. I'm going to try to replace it next.
tarafından
Yorum Ekle
w10632083
I noticed after power outages, I too experienced the issue with water filling but then wash cycle either not running or only running for a few minutes. Doing the 123123123 steps It seems to do a factory reset but doesnt eliminate the problem, completely. After about the 4th factory reset my dishwasher then begins to work properly. (My very novice theory is the water control wheel isnt resetting to position 0 and therefore backpressuring the wash motor, overloading it. With each reset the wheel goes closer to position 0.) *note: the factory reset cycle isnt complete until all lights are off.
Puan 0
4 Yorum:
Same here. I started writing down on a notepad to see if there was a connection between 123 resets and correct wash cycles. Sometimes the 123 resets don't do anything at all...
Long story short, I haven't found a pattern BUT after unplugging the machine for about 30 minutes it will fail once or twice and then work correctly for 8 to 10 times...then it starts failing again (will not wash after filling with water)...back to unplugging the machine for another 8 to 10 washes...
Sometimes unplugging it causes the machine to start working correctly without any fails in between, sometimes 1 or 2 fails are necessary and then it will start working properly again. This is definitely a glitch/bug in how these things were built.
tarafından
Donna, I have noticed the exact same pattern. Also, I am in an area where power goes out 4/5 times a year. I always thought that somehow the circuitry of the washer was affected, but I can't know for sure. The odd thing is how many complaints there are about this. The whirlpool website has ridiculous answers and always recommends calling a certified repairman. I can do it myself if I could get the correct information.
tarafından
Certainly seems like a glitch which Whirlpool SHOULD provide step by step details on how to troubleshoot it. Unless the machine was built incorrectly and you have no choice but to open up the machine and adjust the plastic timer in order to correct it and this is the reason why they just send you t to a repairman. I will definitely NOT be buying a Whirlpool dishwasher again!
tarafından
Thanks for the great post Tyler. The latch was the issue for my Whirlpool gold series dishwasher. Had the same issue of not washing the dishes even after going through the whole cycle .
tarafından
Yorum Ekle
I have a similar problem - sometimes the circulation pump runs, sometimes it doesn’t. It *seemed* to be that I could get it to run by switching cycles, until it didn’t. I tried tripping the latch before running (thank you for that suggestion, I never would have thought of that!), and that worked, but we’ll see after a few tries whether that is in fact the issue.
If so, what is the solution? Is it just a matter of bending the metal catch so it hits the latch mechanism better? replacing the latch? replacing the sensor? And is there a way to test if the latch sensor is failing to trigger?
I am pretty good with tools and repairs, but I like to know what I’m doing before I get in too deep. Any links to repair process would be greatly appreciated!
TIA
Puan 0
3 Yorum:
(I thought) manually triggering the latch worked for me for a while, so I thought that was the issue. However, it eventually just altogether stopped. It ended up being the pump motor which was, ironically, my first guess.
The question is, does it run at all (like fill up) if you don't trigger the latch? It won't run at all if it doesn't sense that the door is closed. So if it seems to go through the cycle, it probably isn't the latch that is causing the problem.
You might, like me, just be having an intermittent problem with the motor, which means it might be about to fail.
tarafından
Hi, Ed, I don’t have an answer for your questions, but I want to give you my 2 cents. I was excited when tripping the latch worked for me also, until it didn’t. So please wait awhile & continue to trip the switch to make sure it will continue to work before deciding to change any parts.
I am still trying to figure out the problem with my dishwasher, but I’m pretty close to conceding & buying a new dishwasher. There has been several times I thought I’d found a way to get it to work consistently (like tripping the latch, 123, turning off the power, and pull & push the door), but each method would work a time or 2, but would eventually not work.
My Whirlpool dishwasher is the BEST dishwasher in the world when it works, but there has been times when I’ve spent hours trying to get it to work. It makes me angry that I have to replace a new-looking stainless dishwasher that is less than 5 years old & it makes me even more angrier that it will be dumped in the landfill! I’m sorry for my ranting!
tarafından
@eatataco Thanks - someone above had mentioned that it fills and empties even with the latch not working properly, but maybe like you it only SEEMS like a fix. Until it doesn't work anymore.
tarafından
Yorum Ekle
I have been dealing with this problem for a while now. I have been on many sites with many suggestions that all work and then they don’t. There doesn’t seem to be one single answer that fixes it all, that is unless you contact Whirlpool and their only solution is to have a repairman come out and look at it. They give no useful advice. What gets me is that when I bought the dishwasher, I kept getting emails for an extended 3 yr. warranty for $320, which now I am glad I didn’t get because it is now 4 years later.
So, my only possible solution is to take that $320 and use it towards buying a new dishwasher which won’t be a Whirlpool.
Puan 0
3 Yorum:
Agree, take the door off, call recycle and buy a quality product. Spend the extra money on a Bosch and you will love it. I have thrown out 2 gold series dishwashers from 2 houses. One was new that I bought and the other was new in the second house we bought. Whirlpool should be ashamed to put their name on anything. Just wait till the French door freezer starts puking water on the floor due to a design defect that cost me over 800 to get repaired or when you have to shut the microwave door hard to get the lower light to come on. All of the above happened within 18 months of buying new. My bad experiences and word of mouth, all true facts, will cost whirlpool a lot more than me in the end. Every chance I get, I recommend not buying whirlpool products. There only suggestion was for me to.buy a service plan. Oh another thing, if your control panel stops working and ice maker and water dispenser quit working. Unplug refrigerator and let it reboot, it will not tell you that in a service manual.
tarafından
Thanks for the additional comments. We had previously bought an Electrolux, which died a quick death right after the warranty expired, and the imported parts were outrageously expensive. I had hoped that at least with a domestic model the parts would be readily available, I didn’t count on hard to diagnose mystery problems.
Oh well. Live and learn.
tarafından
We can only hope companies like whirlpool will quit putting out bad products. They seem to be focusing on looks instead of reliability. You would have thought US companies would have learned from the US car industry mistakes of putting out unreliable products at a low cost. Rust away and fall apart within 5 years. In the end we as consumers want reliability. I just replaced all my whirlpool appliances in a new home with LG, we will see if that works out for me. If not, I’ll use word of mouth to express my displeasure. It will take a1000 positive experiences from whirlpool to make up for my bad experiences with them and since they offered no help to correct the junk, I’ll continue to express my personal experience and recommended avoiding whirlpool as a product.
tarafından
Yorum Ekle
Let me just provide an update the “solution” to my problem that I had praised before.
Changing the door latch does NOT work.
Trying to click the door latch part with a knife/other small object you can poke in there does NOT work.
Tripping the breaker/unplugging the machine and restarting is works sometimes. Or just cancelling the cycle and restarting it.
Honestly, the only thing that reliably works is letting the washer fill and try to run. If I don’t hear the water running immediately after the soap dispenser “pops”, then I know I need to open and close the washer. It takes a minute for it to figure out what’s going on, then it either starts or it doesn’t. I keep opening and closing and waiting the minute until it works and then it works flawlessly with perfectly clean dishes. (Sometimes it will freeze again on the rinse cycle around 1hr10mins left. So I do the same thing until it works.)
No other solution has worked for me. I hate it.
Puan 0
3 Yorum:
Another update to my update....
I finally lost my mind and had it with this washer. By the time I reached my breaking point, I would stand and open/close the door to attempt to get the machine to start again for about 20 minutes. It would work, and then one day it just didn't. Machine would "click" several times like it was trying to start, but then nothing.
I took a chance and bought a replacement circulation pump online at Amazon, flipped the machine over, replaced the pump (easy, and YouTube teaches you in 5 minutes). Flipped it back over, plugged it back in, and now the darn thing works perfectly and has cleaned dishes like a champ for over a week now with absolutely no issues.
It starts instantly and is back to normal. So the solution is to replace the circulation pump.
I am no longer insane.
tarafından
It cost me $55 dollars.
tarafından
Hi Ethan,
Sounds like you've had the same problem I've been having with my own dishwasher, and I'm skeptical a latch is the source of all this. Do you have a link to the pump you bought (I presume it was a Whirlpool model)?
tarafından
Yorum Ekle
Wow, this just started happening to our whirlpool, that’s only 5 years old at the most ! But it seems ,well my opinion is the pump motor is getting harder to kick over an then we’ve got the contact of the latch that helps gets that little bit more juice to turn motor over and then the ultimate happens ,in the next few days or weeks, depending on the pumps usage is a complete fail and probably could get some more time by better connections from jimmying the latch to get every last hard start from cheap pump or longer depending on your time. By then we could have done something better with our time like don’t buy whirlpool anymore. ! That’s that folks, these days nothing is built for long time anymore.Its sad but true. Disposable appliances. Like the guy posted above, the dishwasher,the French door fridge, I’ve had appliance guy out THREE MONTHS after we purchased it an told them to take it back! NOPE THEY WONT! Now it flooded my house an we already had a claim from hail damage so we almost lost our insurance company of 32 years! Oh an yeah slamming the door on the microwave too! Same here dude in post above! screw Whirlpool . I don’t even wanna get in this game of try an fix my POS for a arm and a leg then dies anyways. Go buy something, hey it’s good for the economy. Lol
Puan 0
2 Yorum:
Looks like I'm not the only guy having the same problem with dishwasher. I'm also having same exact problem. Mine is just completed 2 years and warranty expired and problem started. Whirlpool/Kitchenaid has to recall their dishwashers or someone has to file a class action lawsuit.
tarafından
Had a 2yr old Whirlpool that stopped running a cycle. Pulled the unit and removed pump assembly and found the reservoirs around imagined and turbine were full of solid food particles. Cleaned housing and made sure turbines was clear of debris and reinstalled. Worked like a charm!
tarafından
Yorum Ekle
After reading all of the above and trying everything, we resigned ourselves to call out our trusty handyman. Even after cleaning out all the spray arms, we finally gave up after hours of tinkering. The pain was compounded by the fact that we had bought the machine 2nd hand only last week. This morning, we gave it one last go and after a jittery start followed by a thud, it seemed that the incoming water purged whatever it was blocking it and the machine sprung into action.
Puan 0
1 Yorum:
I have a whirlpool portable dishwasher that starts in the begining for 5 seconds and then drains while filling and continues to drain while filling. never keeps water in it. Replaced the float valve and water sensor valve and still not working any suggestions.
tarafından
Yorum Ekle
I had the same problem, in my case, dishwasher will fill water, and heats up the water, but it will not start circulation pump (This happens 5 out of 10 times). But, after some time water will be drained and fresh water will be filled, heat the water and this process goes on.
I have checked the motor, drain pumps individually they are working fine. changed turbulance sensor, float sensor and main computer board. But still the problem didn’t go. I am not suspecting the door latch, as the door locks fine, and water coming in and heater is running. So, I am confident door latch is working fine.
The surprising part is, once I reset the computer 123123123 process, then the first iteration goes perfect, nicely clean all dishes and dry them up. so, confused what could be wrong here.
Puan 0
1 Yorum:
Check this out. It's the circulation pump because of wear and tear. https://www.youtube.com/watch?v=Ki68BVU-...
Sometimes the motor gets into a bind and sometimes it doesn't depending on how worn out the graphite bushing inside the motor is. That's why there's so much inconsistency on when the pump/motor assembly works and when it doesn't.
tarafından
Yorum Ekle
Found a string in the impeller of the pump. Took the pump out— cleaned it— good to go.. model WDTA50SAHZ0
Puan 0
2 Yorum:
Same issue replaced pump and ran through cycles, nothing. Filled but no circulation pump. Tested for continuity and failed. Pump #2 died. Assuming the new pump over heated due to bad latch. Now going to order latch and another pump. So frustrating. I suggest testing new pump for continuity before installing it, because they won't take it back after being installed. Oh and they have a 20% restock fee if they do. Pump was $68.00.
tarafından
I’ve replaced the pump assembly and the dishwasher worked great… 3 times. Then the circulation pump would not start after the washer filled with water. I have noticed that if I unplug the circulation pump, it will reset the dishwasher. Then it runs fine 2 or 3 times before the circulation pump will not turn on mid cycle.
tarafından
Yorum Ekle
Our dishwasher will run everything except will not drain any of the water out even though I can hear it running loudly. I've taken off the pump and it spins fine (though it starts a few times and then stays on through cycle), checked and cleaned the inside for debris, tried the door laych trick but thats fine. Any suggestions?
Puan 0
1 Yorum:
Check all of the drain hoses coming out of your dish washer too. I did this but couldn’t find anything so ended up calling a repairman. He charged me $70 to pull the metal cap the air release on the kitchen sink, unscrew the plastic cover and shine a light inside and pull out a what looked like the plastic safety cap from a carton of milk or broth. He didn’t even remove the hose. He just reached in and grabbed it with needle nose pliers. I checked the hoses but since they were clear hoses and I couldn’t see an obvious clog in the line then it must have been the drain motor or the switch on the board. Also, make sure your garbage disposal is working properly and maybe try a reset on that too..
tarafından
Yorum Ekle
A bit old but I followed this thread with my WDF540PADM 3 with the same sympotms but found it was too different for these steps to apply - it was less than 2 years old at failure. What I did find was the code sheet saying to press the 1-2-3 buttons three times in succession, which did not mean much when you don't have numbered buttons. What they meant was the three selection buttons from the middle to the right side in succession and it flashes the code on the blue LED. It gave me a 4 3 code stating the motor would not start. Unfortunately, only the entire assembly was available on short notice so it was pretty pricey ($347 CAD). That cured it. The parts guy said they have sold lots of them, typically in the first two years.
Looking inside the motor, it is a permanent magnet AC motor with an overload switch inside. The DC resistance on mine was 7.4 ohms which was within spec, so I suspect the overload switch inside the motor itself, which is a Klixon 3mp21904 - actually available on Taobao but it will take 10 years to get here...saving the old one in case it fails again.
Puan 0
Yorum Ekle
We had the same problem with our Whirlpool dishwasher. Bought it in 2019, then it stopped working 4.5 years later.
It would start up, fill with water, drop the dishwasher tab into the water, then nothing.
The wash cycle wouldn't start, the sprayers weren't turning or cleaning the dishes. Then it would drain the water, do a steam dry, and stop. But the dishes were still dirty.
I tried messing with the door latch but that didn't fix it.
I flipped the circuit breaker, jiggled the 2 blue wires underneath (connected to the motor), and gave the motor a couple good smacks just in case.
Magically, it worked again! Fingers crossed it keeps working. But at least I can repeat these steps in the future if needed.
Puan 0
2 Yorum:
We solved our problem! Ours would start and fill but then nothing. It would drain when turned off so I knew the electronics were working. Unplugging it and resetting it made no difference. Our solution was to unplug it and turn off the water under the sink. We then slid it out and disconnected the drain pipe. Laying the machine on its back gave access to the bottom. We disconnected a small white clip from the pump assembly and rotated the pump assembly off easily. It was all clogged with food and grease. It is magnetic and comes apart easily to clean. After putting everything back together and it runs a full cycle perfectly.
tarafından
So my dishwasher will start running cycle and then just shut off and won't show any power to anything until like 20 minutes- 24 hrs later. Like no lights on the control panel or nothing like it's just dead. But then comes back unexpectedly. I've tried control panel reset, hard reset just about everything and still does same thing nothing changes. Any ideas my dishwasher is a whirlpool model# WDF330PAHW4
tarafından
Yorum Ekle
FIXED!!
This was my issue! After many videos, posts by others, this is what finally set me on the path to correct the problem!! It indeed is the circulation pump and the bushings failing. HOWEVER whirlpool DOES NOT just sell this part!! THEY want you to buy an entire new pump (well over $100). I found this video with instructions on how to remove and clean the pump (mine did have "some" calcium build up in it but you can feel the sides of the interior where it spins out of center and cuts grooves into the inside chamber - this is what shows that the bushings were bad)
Here is video I watched that I found to be most helpful.
HOWEVER Since I do not have means to make my own bushings,like in the video, I found this guy on EBAY and the parts worked like a charm.
Kenmore Whirlpool KitchenAid Dishwasher Pump Motor Bushing W10610147 W10846093
https://www.ebay.com/itm/334815086153
GOOD LUCK!!! These dishwashers are designed to fail so we buy new ones!!
Puan 0
Yorum Ekle
Had a similar problem, for me it was solved by opening the door after it stopped filling with water and manually giving the soaker arms a spin. Closed the door and it started working again.. 🤷‍♂️
Puan 0
1 Yorum:
After tearing my dw apart I discovered the pump motor was worn and if you jostle the machine it would start. The motor bearing had failed on this relatively new unit. Cheap motor. Scrapped it and got a new one. Different model.
tarafından
Yorum Ekle
Yanıtını ekle
radicalng8 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 49
Son 7 gün: 463
Son 30 gün: 2,437
Her zaman: 408,056
