Ana içeriğe geç
2009 yılının başlarında çıkan Mac Pro —diğer adıyla Mac Pro 4,1— Mart 2009'da Apple'ın profesyonel masaüstü bilgisayar serisine Intel'in Nehalem mimarisini getirdi. Mac Pro 5,1 aynı iç tasarımı kullandı ancak 2010 ve 2012 yıllarında ek CPU güncellemeleri aldı.
Kernel panic on startup after cpu upgrade
So, I was thinking of upgrading my early 2009 Mac Pro 4,1 Nehalem dual Quad-Core 2.26GHz to a Westmere 12-core but before getting my hands on such CPUs I thought I’d try out a couple of x5570 2.93GHz quad-cores (lidded, fitted with washers and 5mm thermal strips, I happened to have laying around.
The machine is firmware upgraded to 5,1.
I had to re-set cpu b about a million times before the computer would boot without any blinking power button or red lights on the backplane.
It boots fine with any of the two single processors on its own (with red light and fan at full throttle) but when both are installed I get kernel panic on startup.
I’ve reset SMC, started up with opt+R+P and nothing helps. It won’t boot in recovery mode either.
I’ve also removed the Northbridge heatsink and cleaned up the dried thermal paste and reapplied with new.
See linked picture of panic screen here: Kernel panic
(I don’t understand aaanything of it)
Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
What system are you running and how was the firmware flashed?
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Resim
Im having the same problems. Mayer any ideas?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Did you solve the problem? I've got the same trouble
Puan 0
Yorum Ekle
Hi,
I gave up for a while, then I refitted the cpu’s 20 more times and then the kernel panics stopped. However one of the heatsink fans isn’t working and I can’t figure out why, maybe the board, maybe the heatsink fan itself. Good luck!
Puan 0
Yorum Ekle
how thick washers? I used 2 M4 (2.2mm) How tided screws?
Thats for beginning - I need to give MANY more specific informations - if not - no help :(
Puan 0
Yorum Ekle
hello
i have also questions about problems with the cpus not detected,
the no-booting mac :-(
have to check if the processors are already working
have to check if no pins are bent on the socket under a cpu
i found that..
https://www.imore.com/how-upgrade-your-o...
1) the black connectors of the heatsinkers ,
have to be reseated (a little bit out of their original position).
to be perfectly connected.
2) doing this tricky operation… NEVER OVERTIGHTEN the springscrews when seating back the sinkers.
cross pattern. never press on the top of the sinker.
count the number of rotations before (when removing the sinkers),
note them, and reproduce them with care
3) have to respect the difference of thickness of a delidded cpu and a lidded one. (3mm or 5mm),
this layer…. with 3 or 3 washers?
5mm thickness of thermal strip ? he removed the original pink layer.
Puan 0
Yorum Ekle
Yanıtını ekle
Daniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 1,364
