Ana içeriğe geç
2014 yılında Xiaomi tarafından üretilen, 7,9 inç ekrana sahip 16 GB kapasiteli Android tablet.
What is this component?
Hello everyone.
I'm actually trying to replace my Mi Pad 2 screen + digitizer. When i tryed to unstick the broken screen + digitizer from the frame i made a damages on a component stick to the frame.
This photo is going to show you the front panel empty ( i left the broken screen + digitizer)
Resim
I zommed on top left of this front frame where is the damaged component.
Resim
on the back of the frame at the same place there it his other part of this component
Resim
I'm supposed to plug the mother borad on this :
Resim
Do you think this component is important? It's write on this : "0 w1 mp aac 160328"
Thanks for support =)
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello mates,
Thanks you so much for react fast like this.
When you said "radio" do you mean FM Radio, same radio that every one can have in his car?
Because the wifi is a radio sgnal (in other frequency).
Will only the FM radio be impacted or all orther radio signals like wifi and bluetooth?
Thanks you again ;)
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
probably all signals, but the damage is so minor that the effects will be negligible. So you have nothing to worry about.
tarafından Paylaş
WiFi and Bluetooth. Because those two usually use foil antenna under the glass or rear case, while FM radio uses your headphone wire as the antenna. Also I’m bot sure if your device has FM radio to begin with.
tarafından Paylaş
Yorum Ekle
En Yararlı Yanıt
Antenna, you may degrade or destroy radio performance if you damage that part.
Puan 1
Yorum Ekle
Tom chai is correct on what is. As for importance, it should still function perfectly fine with the damage, but as Tom said, it wont be as good as it used to be but it should be perfectly fine for what your using it for.
Puan 1
Yorum Ekle
Thanks for the info,
i was wondering informations before order a new screen kit ( about 50$ ).
Thanks you so much. I still use an old 2012 galaxy s3 4g that run perfectly android 6.0.
Smartphones hardware upgrades is bullshit most part of time.
see you my friends.
Puan 0
Yorum Ekle
Yanıtını ekle
Matteo GACHON sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 514
