No start or crank
Battery is good checked all the cables and fuses are good still nothing
Bu iyi bir soru mu?
Bu iyi bir soru mu?
First, turn on headlamps. If they're bright, and don't dim when the key is turned, the battery is o.k. listen for a click. if you hear any click, it's probably the starter. No click - try turning the key with the shifter in "N" Nothing - back to Park. At this point, it could be anything; ignition switch, neutral safety switch, open wiring, etc. If you want to pursue it yourself, you have to get a wiring diagram and test point to point. It can't be diagnosed on line.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 3,032
