Ana içeriğe geç
HP Envy 15 x360, 15-Uxxxxx model numarasıyla tanımlanabilen bir dizüstü bilgisayar-tablet hibritidir.
Storage Upgrade HDD + SSD
Does this laptop has dedicated SSD slot, so that i can have both HDD and SSD together
Bu iyi bir soru mu?
Puan 1
1 Yorum
Your systems specs: HP ENVY 15-u010dx x360
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sorry, It appears not
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I purchased a newer model the 15cp something something, it has a slot for an ssd, and if you are using a hard disk it definitely has one. The envy also comes with an m.2 slot, if your local storage capacity is less than 256G from the original purchase, you are very likely to have the m.2 slot, however if not then you are most likely running of a hard disk. There is space underneath the case for the old sata style drive, however it does not come with a cable, and you would probably have to go out and buy one. Good luck!
Puan 0
Yorum Ekle
If I upgrade the RAM, will it void the warranty?
What kind of ram will I need to buy?
Will the rubber feet go back on?
Thanks!
Puan 0
1 Yorum:
I have the 2017 model the one with the mx150, 512gb , 16gb ram etc. Upon opening it up just now, I discovered everything is soldered on, except the wireless network card. In my case I have an empty space for an HDD which you can upgrade if you buy a bracket from HP or otherwise. The rubber feet will not go back on. You will need new double-sided Tape. No RAM upgrade sadly.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Prashant sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 2,888
