I can not enable the video mode
when the screen comes on a little display comes up in the top left corner that says video mode disabled. i have done the on volume button thing with no results
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Rob Vitale start with a hard reset. You will lose your files like pictures, music etc. when you do this.
You need to hold down the volume up button then press the power button for a few seconds until the tablet turns on, releasing power button, you should now be getting the recovery menu.
Bu yanıt yardımcı oldu mu?
after i did that. the screen came up with...magicware mismatch. critical failure, unable to start kernal. unrecoverable bootload error. whitch means is that it is stuck in a loop.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 106
2 Yorum
Rob Vitale by this "done the on volume button thing " you mean a complete hard reset?
oldturkey03 tarafından
Ok. I hold the on button and hold the volume down button. It goes blank. Then it comes on for 1 second and on the screen it says that the UI launcher has stopped. Then freezes up. I did the same thing with volume up. It's not happening. All I wanted to do is clear the cookies and reset the app. preferences.
Rob Vitale tarafından
