Ana içeriğe geç
The first 8 inch Android tablet by Samsung.
50 Soru Tümünü görüntüle
Why does my tablet keep freezing?
Hi my tablet keeps freezing, I have tried a factory reset but that still hasn't helped. Freezing seems to occur randomly . Usually it's when I try to play a game but it's also froze when I'm doing nothing. Once the tablet is froze I have to hold the power button down to get it to restart and it occasionally hangs on the Samsung logo, which requires me to hold power button again and again until it decides to boot . My battery is pretty poor and the tablet spends most of its life on charge. Is it possible this is a battery issue or something else?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
7 Yorum:
its not a battery issue I would recommend to get it checked somewhere
tarafından
Not sure what else it could be other than the battery, I've done a hard reset so it's not the software,it's not water damaged or anything .anything else I could check?
tarafından
Did you just factory reset your phone through Settings or flashed the ROM? If not, try it.
tarafından
Just factory reset. I will try flashing today
tarafından
So I have flashed stock firmware and still freezing, I have noticed that it only really freezes after the tablet has been charging. Sounds like maybe the tablet is overheating while charging maybe? Any ideas?
tarafından
2 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try freeing up space that should speed it up.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I don't need it to speed up, just to stop freezing
tarafından
Buy a SD card which will give you more hard drive space.
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 5,361
